G major relay switching on a 3 ch Dual Rect? Help needed - Jemsite
post #1 of 4 (permalink) Old 04-24-2003, 10:11 PM Thread Starter
Hi..
I'm in the market now for a G major after hearing all the good things abt it. What really caught my eye was the relay switching function.
However, my qns is, how do you connect the relay jacks to the 3 channel dual rect? I'm aware that there are 3 external outputs on the dual rect for each of its channel, one more for solo and another for effx loop. However, on the G major, I think there's only one output for relay switching? What type of relay jack is necessary? A Y splitter? A Stereo? or what can be done such that I can switch the 3 channels as and when I change presets via a midi footcontroller?
Any help is appreciated!
Thanks!
triaxis is offline
post #2 of 4 (permalink) Old 04-24-2003, 10:29 PM
The G-major has a stereo jack, so with a Y-cable, you can switch 2 items at a time.
I don't think that will do the trick for the Rec... I wanted to use the G-major to switch the channels on my Mark IV, and I could only switch 2 of the 3 channels.
I ended up buying a Rolls/RFX RP-93 to swtich channels on the Mark IV--it can switch 4 relays at a time. Combined with the G-major, I get major MIDI switching:
Rolls switch 1--R1 channel
Rolls switch 2--R2 channel
Rolls switch 3--LD channel
Rolls switch 4--graphic EQ
G-major switch 1--FX loop
G-major switch 2--reverb
Good luck!
--B
bduersch is offline
post #3 of 4 (permalink) Old 04-24-2003, 11:05 PM Thread Starter
Hey..thanks a lot for the information...I'll try to look for the Rolls/RFX RP-93 ..I think that should be sufficient for me...thanks!
triaxis is offline
post #4 of 4 (permalink) Old 04-25-2003, 07:24 AM
The RP93 is a heck of a deal--it's $150 new, generally $90-100 used. In addition to the 4 switches, it also has 4 loops, so you can use it to switch pedals in and out of your signal chain.
So aside from using it to switch the channels on my Mark IV, I also use it to switch my TS9-DX and CP-9 in and out of my signal chain.
--B
bduersch is offline
midi foot , midi footcontroller
How does the JEM7VWH sound through a Dual Rect ? Muddy? triaxis Ibanez JEM, UV, JS & Other Signature Models 17 09-26-2008 06:01 PM
FS: Mesa Dual Rect 3 channel. near mint $1250 OBO lttoler Classified Ads: Guitars and Gear 5 04-14-2007 09:51 PM
Single Rect versus Dual Rect?? - Whats the difference in ton triaxis Gear, Equipment, Recording & Off Topic 14 06-09-2006 03:23 AM
Rivera TBR-1SL/G-Major Pre-amp channel-switching question vaijem777 Gear, Equipment, Recording & Off Topic 1 09-03-2002 09:54 AM
TremOVerb Vs Dual Rect - any difference in tone? triaxis Gear, Equipment, Recording & Off Topic 10 10-24-2001 05:15 AM
