G-system pedal loop low - Jemsite
post #1 of 21 (permalink) Old 08-09-2007, 12:02 AM Thread Starter
when I connect my drive pedal to the g-system loop it takes distortion away rather than add distortion. I check all my connections and parameter...How do I fix it and use it properly?
I am using the standard text book connection to a stack.
the pedal I have tried using is a Boss ds-1
Quiksilver98 is offline
post #2 of 21 (permalink) Old 08-09-2007, 12:30 AM
Re: G-system pedal loop low
When you step on the physical pedal to turn it off (not the g-sys buttons) what happens?
fyrie is offline
post #3 of 21 (permalink) Old 08-09-2007, 12:31 AM Thread Starter
Nothing, if the g-system loop 1 is on, then it reduces the sound even more by turning the pedal off.
post #4 of 21 (permalink) Old 08-09-2007, 12:36 AM
it's broken send it to me.......
newbieguitarmaker is offline
post #5 of 21 (permalink) Old 08-09-2007, 12:40 AM Thread Starter
Naa, i will rather throw it in the trash...
post #6 of 21 (permalink) Old 08-09-2007, 12:41 AM
I would search through your garbage, its legal once its on the street curb
post #7 of 21 (permalink) Old 08-09-2007, 12:44 AM
So if I am hearing this correctly:
G-Sys without the loop on:
-Distortion
G-Sys with the loop on with a turned on distortion pedal:
-Less distortion
G-Sys with the loop on with a turned off distortion pedal:
-Even less distortion
-- But not "clean"? Meaning you are still getting distortion from your amp, or is it clean at that point?
fyrie is offline
post #8 of 21 (permalink) Old 08-09-2007, 12:48 AM Thread Starter
almost at the clean point. And yes got it all right.
post #9 of 21 (permalink) Old 08-09-2007, 12:56 AM
As per my post on vai.com, I think the insert loop is off in the patch. If you aren't getting the amp's distortion using the 4 cable method, your insert loop is off.
search this gear page thread for the term "insert":
http://www.thegearpage.net/board/showthread.php?t=88835
fyrie is offline
post #10 of 21 (permalink) Old 08-09-2007, 01:20 AM Thread Starter
i am getting my amps distortion. I figured that one out, i'm talking about my DS-1 in my loop1 of the g-system.
post #11 of 21 (permalink) Old 08-09-2007, 01:42 AM Thread Starter
I looked and didn't find any info on my problem.
post #12 of 21 (permalink) Old 08-09-2007, 12:52 PM
There there is a loop level and a loop headroom setting. You could try messing with those. I would guess to turn up the loop you would raise the level and lower the headroom.
fyrie is offline
post #13 of 21 (permalink) Old 08-09-2007, 10:53 PM Thread Starter
nope. dont work.
post #14 of 21 (permalink) Old 08-10-2007, 07:40 AM
I had similar problems, did you check your signal routing and modify the parallel and serial configs?
Ultimately I ended up sending mine back after about 3 weeks. The place I bought it from had a 30 day money back policy.
The thing that gets me is Vai uses one live, and I'm sure he has Thomas Nordegg just sit and perfect the thing. Meanwhile, you 're thinking, ahh, Vai's using it, I should be able to handle it.... Pfffft
The concept behind it is great, but sadly, it doesn't work for everyone in all situations.
bammbamm is offline
post #15 of 21 (permalink) Old 08-10-2007, 03:49 PM Thread Starter
Vai apparently uses in 2 cable method in which case IT'S really easy to use.
distortion pedal
Wanted: Loop Pedal sihackett29 Classified Ads: Guitars and Gear 1 02-12-2007 06:08 PM
FS 2nd Greatest Distortion Pedal Ever elcid Classified Ads: Guitars and Gear 1 12-02-2006 06:24 PM
ghost buster + loop pedal =video Dragon Slayer J Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 09-25-2006 09:36 PM
Vol pedal in FXloop help. Answer to low volume tube heaven? track7 Gear, Equipment, Recording & Off Topic 16 01-28-2004 09:57 AM
Possibly the best pedal I've ever owned jay ratkowski Gear, Equipment, Recording & Off Topic 31 08-02-2001 02:54 PM
