Good rack based noise supressors/gates - Jemsite
post #1 of 2 (permalink) Old 11-23-2005, 11:06 AM Thread Starter
Any recommendations? I tried the rocktron hush super c and it really didn't do what i wanted it to.
I normally place the gate just before the power amp, or in the last stage possible to get rid of as much as possible. This may be the wrong place though, I dunno.
Any case, what i want it for is to partially gate the guitar signal, and then to get rid of a lot of the noise introduced by the triaxis.
help?
7 Dying Trees is offline
post #2 of 2 (permalink) Old 11-23-2005, 02:26 PM
Re: Good rack based noise supressors/gates
the ISP Decimator ProRackG is a two channel noise reduction. the first channel is used to eliminate sound from your guitar (60/50 cycle hum, pedal noise, etc). then the second channel is used to clean up noise coming from your preamp. run in the loop. Rack effects (at least in my experience add almost no noise to your signal, so it's best to put the noise reduction right after your preamp. Here is how i will be running mine when i get all the cables i need.
guitar -> pedals -> ProRackG Ch1 -> Mark IV input
then in loop
ProRackG Ch2 -> GMajor -> BBE
i bought the unit based on very reviews and sound clips.. so we'll see how it turns out.
adamcbest is offline
isp decimator , power amp , rocktron hush
How many Noise Gates? D.M.RG7620 Gear, Equipment, Recording & Off Topic 18 02-19-2012 12:23 PM
WTB poweramps, preamps, noise gates etc John.E.Fawkes Classified Ads: Guitars and Gear 0 02-19-2009 11:55 AM
noise gates Praetorian Gear, Equipment, Recording & Off Topic 6 03-20-2005 06:48 AM
Who uses noise gates? Whaddya use? bduersch Gear, Equipment, Recording & Off Topic 5 11-09-2002 06:40 AM
Is USB good for computer-based recording? - Fast enough for babahi Gear, Equipment, Recording & Off Topic 4 02-13-2002 03:45 PM
