guitar power amp vs. PA power amp - Jemsite
post #1 of 7 (permalink) Old 09-01-2003, 01:41 PM Thread Starter
can i use with (almost) my PODxt, any power amp or has it
to be designed for guitar? i've noticed that you can get like
300 watts under 400$! All the tone 'thingies' are on the POD,
so the power amp would give only volume. Is this right?
pace520 is offline
post #2 of 7 (permalink) Old 09-01-2003, 05:43 PM
Re: guitar power amp vs. PA power amp
That's up to you. Try it with a PA amp, and if you get the sound you want from the Pod, go for it. Some people think that a tube guitar amp adds "a little something extra". So try one of those, too - see if it makes a difference to your ears with your gear.
JESTER700 is offline
post #3 of 7 (permalink) Old 09-02-2003, 05:05 AM
Do you mean a tube simulator Power amp? Or Runing the pod through a tube head. i dont know much about these, but am keen about getting a pod pro with a power amp and runing it like a half stack.
Benno is offline
post #4 of 7 (permalink) Old 09-02-2003, 08:01 AM
I meant a real tube power amp. That is, one with power tubes - these will be EL6s or similar - bigger than the little 12ax7 preamp tubes you see a lot of.
My thinking is, there are 2 options (which you've already caught on to):
1) rely on the POD for the total sound and use a clean power amp to only amplify, not color, the sound. In this case, you should actually be able to use a full range speaker like a PA speaker, since hypothetically your sound is just as you want it from the line out of your POD. But usually people use normal guitar speakers so other guitarists don't giggle. If you go this route, you could also use a full range combo amp for convenience, like an amp made for keyboards or acoustic guitars. If you go the stack route, just get some good, clean, cheap power. Go talk to some PA guys & see what they like. I use Crown & QSC, but there are lots of good amps out there.
2) Use the POD for most of the sound, but also color it some more with a tube amp. As mentioned at the beginning, look for REAL power tubes if you do this - avoid the ADA single rack space amps that use a preamp tube with a solid state amp. IMO, of course.
post #5 of 7 (permalink) Old 09-02-2003, 09:26 AM Thread Starter
i've noticed that all the PA power amps have Neutrik speakon
outs. I's there some adaptor to chance the speakon to normal
plug? 'cos almost every guitar cab has a plug inputs.
pace520 is offline
post #6 of 7 (permalink) Old 09-02-2003, 02:33 PM
Not all do. You can find some with 1/4" outs. But yeah, adaptors are available for any combo of 1/4", speakon, and bananas.
post #7 of 7 (permalink) Old 09-03-2003, 05:15 AM
Just some thoughts from my own experience. I find that my gt 6 sounds a lot better going through PA or keyboard amp than guitar amps.
poet is offline
acoustic guitar , combo amp , pod pro , power amp , power amps , preamp tube , rack space , solid state amp , tube amp , tube head , tube power amp
WTB: Voodoo Lab Pedal Power 2, BBE Supa Charger or MXR CAE Power System Levi79 Classified Ads: Guitars and Gear 2 12-23-2010 01:06 AM
Voodoo labs pedal power 2 plus or normal power strip? SilverSurfer2 Gear, Equipment, Recording & Off Topic 2 05-21-2009 11:20 PM
BOSS PS-2/CE-3/TU-2/OC-2/T.C. Electronic power supply/MORLEY Power Wah BOOST Sevenstringer Classified Ads: Guitars and Gear 12 05-09-2008 04:05 PM
Feeler FS: Tech 21 Power Engine PE-300 Mono Power Amp Drache713 Classified Ads: Guitars and Gear 1 03-04-2008 01:35 AM
Power supplies, preamps and power amps - whats the more idea tomizm Tech: Setup, Repairs and Mods 2 04-11-2001 06:56 PM
