head cab and ohm question - Jemsite
post #1 of 5 (permalink) Old 03-06-2011, 11:07 PM Thread Starter
Reviews: 4
Hey guys i gotta noob question about cabs heads and ohms.So I'm looking at getting my first half stack and I really have no clue on how to tell what heads can be used on what cabs.Obviously a head and cab that are both 8 ohm can be used together,but what if the head is 8 ohm and the cab is 12 ohm? would the thing set fire or something? And lets say it was the other way around and the head had higher ohm then the cab then what would happen? Its a noob question but I'm sure you have all bin in my shoes before.I just want to make sure I understand this before I spend money on a head and a cab that could end up causing a fire or something.
guitarnub3 is offline
post #2 of 5 (permalink) Old 03-06-2011, 11:25 PM
Reviews: 64
Re: head cab and ohm question
Cab has to be the same or higher value than the head.
Never lower
And there are specific cables to connect a cab to a head hence the fact those cables carry current.
My guess is they're called speaker cables in english.
6fingers is offline
post #3 of 5 (permalink) Old 03-06-2011, 11:48 PM Thread Starter
Reviews: 4
Thanks for clearing this up for me Its allot simpler and allot less intimidating than I had thought haha.
post #4 of 5 (permalink) Old 03-07-2011, 12:16 AM
Reviews: 12
Exactly, and from my understanding, if you do run said setup you can overheat the amp causing damage to the tubes and/or circuitry, no explosion though
GroovyTubes is offline
post #5 of 5 (permalink) Old 03-07-2011, 03:31 PM
Reviews: 11
What happens is you burn the output transformer up which will cost you some serious bucks to replace. Avoid mismatching and you avoid the fireworks. And NEVER run your amp without a load connected.
Riffraff is offline
half stacks , ohm
Ibanez head + cabinet ohm question ZOMB13 Gear, Equipment, Recording & Off Topic 0 05-31-2009 10:24 PM
FS: Mesa F-50 head and Budda Superdrive 30 head lttoler Classified Ads: Guitars and Gear 0 07-21-2008 06:08 PM
Custom 4x12 question - (50w head vs 16 ohms) Josh_P Tech: Setup, Repairs and Mods 2 03-01-2007 08:06 PM
FT: Line 6 Vetta Head for Randall MTS Head or Combo JiMoSiTY Classified Ads: Guitars and Gear 0 10-21-2005 10:30 AM
WWT my XXX head for high watt ss head with on/off loop nick1 Classified Ads: Guitars and Gear 6 06-01-2005 02:16 PM
