Headphone/Record out Mesa F50 Focusrite - Jemsite
post #1 of 2 (permalink) Old 06-29-2017, 05:06 AM Thread Starter
Hi there, I've tried googling but come up with mixed results.
My setup for recording so far has been the Reaper DAW on a custom PC with a Focusrite Clarett 4 Pre and Yamaha HS8 monitors. I've got some good tones tweaking free plugins (LePou and Vadim Taranov) and some cab impulses however for clean sounds I am struggling a lot.
Can I get some good clean sounds going from my headphone/record out on the back of the F50 and flicking the silent record switch then monitoring through the computer? I am very happy with my amp, guitar and pedal combos. Any guitar I currently have with a Keeley 4 knob compressor as a clean boost into the front of the amp sounds great. Add some effects post and I imagine it could be very good on the computer?
If this is a good option do I need an instrument cable, audio cable or Y trs cable to make this work? Do I go into one of the 4 inputs on the front or use one (or two) line inputs on the back of the interface (if I use either a Y TRS cable or audio cable)?
Many thanks
Ian
Daft_Dude is offline
post #2 of 2 (permalink) Old 07-23-2017, 12:36 AM
Re: Headphone/Record out Mesa F50 Focusrite
Cables: Connect your F-50 Record Out using a TRS - TRS cable to one of the Focusrite Line Inputs on the back of the interface.
Clean tones: I think your plan is as good as any. The Record Out will probably need some help from your DAW/plug-ins to get a good clean tone. The reason is guitar speakers flatter the guitar signal/amplifier wizardry where as studio monitors do not.
Mesa/Boogie F-Series Manual - http://www.mesaboogie.com/media/User...s/F-Series.pdf
Since this thread is a month old, I'm sure you have found some solutions but I thought I would contribute in case future generations have the same question. Hopefully, I have not led them astray.
Formerly Given To Fly is online
headphone record direct
FS: Focusrite Saffire 6 USB Interface satchmo72 Classified Ads: Guitars and Gear 1 11-27-2013 10:18 PM
F50 - A whole bunch of questions dark_void86 Gear, Equipment, Recording & Off Topic 6 12-05-2010 03:36 PM
Mesa Boogie F50 nsabino Gear, Equipment, Recording & Off Topic 1 02-20-2010 05:24 PM
I bought me an Mesa boogie F50! jemke Gear, Equipment, Recording & Off Topic 3 02-13-2005 08:20 AM
Headphone for monitoring - I want a headphone that sound Nat cowcowcow Gear, Equipment, Recording & Off Topic 13 01-22-2002 09:51 PM
