Heil/Dunlop Talk Box - Jemsite
post #1 of 2 (permalink) Old 08-15-2003, 01:12 AM Thread Starter
Anyone have one of these things made famous by Frampton, Sambora, Slash, et al? I just got one not to long ago. Been messing around with it and my marshall MG100 and I never can get the volumes to balance. When I set the amp to a level so the mic picks up the sound out of the talkbox, switching back to just the amp blows down my house. The levels are just way unbalanced. I was thinking about getting an A/B switcher, and just using my POD to drive the talkbox, or just use my marshall to drive it and use the pod on a lower wattage amp. Whoa...kinda a long rant there , just wondering if anyone else has a talkbox, and there opinions on it and whatnot.
Matt
untitledblinkfan is offline
post #2 of 2 (permalink) Old 08-15-2003, 05:33 PM
Hi,
Sounds like you might have a mike/pa issue. All the talkbox is, as you probably already know, is a metal box with a speaker, plastic tube, and a bypass switch. So if you're having to crank your amp to get your mike to pick up the sound it might be:
1) bad mike/mike cable, etc
2) do you have the ohms matched up? I think the talk box [email protected] 8 ohms
3) What are you running the mike into? Do you have a mike pre, are you running into another amp? or a p.a board? It does matter, some mikes have much lower output than others and need a mike pre to boost the signal.
I regularly use a heil with a mesa triple recto into a P.A system with a SM 57, and have no problems with balance. It also depends on what kinda sound you want out of it as well. Do you want to use the heil as an accent or are you intending on using as a large part of your sound?
The heil isn't bad, but another company makes a self-power one, which seems like a good idea...but I can not remember right now which company it is...its not an obscure one to be sure. Hope that helps, at least gives ya some other tangents to go on to solve your problem. Good luck! Tobe
tobe is offline
triple recto
FS: Fulltone Ultimate Octave, Boss DD3, Heil Talk Box vaijem777 Classified Ads: Guitars and Gear 2 01-22-2008 11:00 AM
FS: Fulltone Ultimate Octave, Heil Talkbox vaijem777 Classified Ads: Guitars and Gear 1 01-07-2008 11:14 AM
FS: Talk Box Guitarmiester Classified Ads: Guitars and Gear 2 11-05-2007 05:39 PM
Talk Box Guitarmiester Classified Ads: Guitars and Gear 1 10-14-2007 04:46 PM
Talk me out of a Jem... Darin Ibanez JEM, UV, JS & Other Signature Models 51 07-21-2007 05:58 PM
