help with boss gt 10 - Jemsite
post #1 of 8 (permalink) Old 08-05-2012, 09:47 PM Thread Starter
hi recently i brought a boss gt 10 guitar processor.... when it was new it had a patch on there which if u pluck or strum hard on the bridge pickup would play drive and if you play softly it would sound absolutely clean. if u played it hard on any other pickup position its would sound clean but only drive would kick in when played hard on the bridge pickup... well i lost that patch now and i cannot find it anywhere... anyone know where i can find it of the name of the patch?
fizwan is offline
post #2 of 8 (permalink) Old 08-06-2012, 04:48 PM
Reviews: 12
Re: help with boss gt 10
The GT-8 had a feature where it would switch between two amps so you could hvae one clean one dirty you cna set the picking intesity to go from A-B so the lighter plays the clean amp and the harder dirty amp, I would think the GT-10 ha that feature also.
The simplest way to get it back is restore to factory settings, I would check out Boss GT central and really learn how to change what you want in the unit, take s abit longer but is worth it...
ozzuk is offline
post #3 of 8 (permalink) Old 08-06-2012, 08:44 PM
No need. The factory presets are stored alongside the user presets...just cycle a bit till you reach them.
Viper-sfm is offline
post #4 of 8 (permalink) Old 08-06-2012, 10:05 PM
The owners manual has all the factory patches along with their descriptions & call numbers on the last few pages. Just look it up!
kfssdude is offline
post #5 of 8 (permalink) Old 08-08-2012, 11:15 AM
jb4674's Avatar
Reviews: 18
Yep, look at the owner's manual and it should tell you which one it is. I believe Boss calls it "dynamic mode". Unless you have a ton of custom patches, you can always reset the unit to factory specs and it should bring back the patch.
Boss generally gives you half of the available presets to create on your own and half are the factory presets which cannot be overwritten.
Jimmy
jb4674 is offline
post #6 of 8 (permalink) Old 08-08-2012, 11:48 AM Thread Starter
thanks guys ill have a look in the manual. if not ill just reset the gt10 and look for them.
fizwan is offline
post #7 of 8 (permalink) Old 08-08-2012, 01:42 PM
Dude, I'll repeat. There's no need to reset. There are two sets of presets in the GT-10. One is for the user, and the other set is the factory presets. When you reset it, it basically copies the factory presets over to the user presets. If you go to U01-1 and move the circle anti-clockwise you should get to the factory presets. The factory presets are not editable, so the patch you are looking for is still there.
post #8 of 8 (permalink) Old 08-08-2012, 01:59 PM
Absolutely true. Don't need to reset if you don't want to. The U-banks are user definable, but the P-banks are preset & can't be overwritten. If the patch you want is a factory patch, it's still in there. No reset required. Just look up the patch number in your manual.
kfssdude is offline
roland boss gt 10
PatchMate, Whammy II, Xotic RC, Boss TR-2, POG, TC Phaser, Digi RV-7, BOSS DS-1 Sevenstringer Classified Ads: Guitars and Gear 8 05-30-2012 08:32 PM
FS: BOSS MT-2 (Metal Zone), BOSS TR-2 (Tremolo), and DiMarzio PAF Pro redaxe Classified Ads: Guitars and Gear 0 04-17-2012 09:55 PM
FS Boss Pedals, Boss Pedal Board, and SD Pickup Booster CosmicDebris Classified Ads: Guitars and Gear 3 09-17-2008 07:18 PM
Original TC XII Electronic Phaser& Power Supply, BOSS TU-2, BOSS OC-2 Sevenstringer Classified Ads: Guitars and Gear 1 10-23-2007 06:57 PM
WTS: Boss Super Chorus CH1 & Boss Compression Sustainer CS-3 Clydefrog Classified Ads: Guitars and Gear 1 07-15-2006 12:57 PM
