Help choosig between these amps!!plz! - Jemsite
post #1 of 6 (permalink) Old 10-09-2010, 03:22 PM Thread Starter
Hello everyone,
I've done my part of the research but I'm still afraid I'll choose the wrong amp...I like all of the following but I'll finally choose by combining your thoughts with mine!
Here are the amps I can buy (used) :
1) Marshall 6101 LM combo. one of the 97-99 models
2) Marshall DSL 401 or 201 combo
3) Peavey Classic 30
4) Blackstar HT club 20
I know the 6101 will rock my world but I'm having some of the following thoughts...1)1997-99 is quite old and I'm afraid of beeing the user that the amps fails on after all these years...am I wrong?? 2) Some people say it overheats to meltdown...will a fan solve my problems completely??
I could also buy a JSX head which I'm so in love with but unfortunately I have no use for it since we rehearse at my place and gig 2 times a month at most.
I need an amp that will play at low volumes and loud to keep up with band by micing it or by hooking up a 2x12/4x12. I will also be using the amp for recording. We play instrumental rock music and I'm the lead guitarist in the band.
What are your thoughts??
constantine is offline
post #2 of 6 (permalink) Old 10-11-2010, 12:22 AM
Re: Help choosig between these amps!!plz!
I dont know about the overheating issue but just because the amp is a little old doesnt mean its gonna break
thenos is offline
post #3 of 6 (permalink) Old 10-11-2010, 02:24 AM
Reviews: 120
HT20.
LonePhantom is offline
post #4 of 6 (permalink) Old 10-12-2010, 10:03 AM
the over heat issue is a Marshall model problem most were solved by installing a fan never heard about any peavey 30 over heat issues
rlee1031 is offline
post #5 of 6 (permalink) Old 10-12-2010, 01:55 PM
Ive never come across anyone who dosent love a Blackstar, I have the HT20 Head and cab and its fantastic.
mattacuk is offline
post #6 of 6 (permalink) Old 10-12-2010, 02:20 PM
Reviews: 59
The Blackstar is great, I also like the JSX and I'm sure you can get one cheap now that they're discontinuing the model. It sounds good at lower volumes and awesome when turned up. I'd probably go for either of those.
I would have the same concerns with the 6100 as the JSX with it's volumes and usage in your circumstances (not that it isn't a great amp).
I'd probably consider the Classic 30 a step down from the others even though it's a very capable amp.
smooth55 is offline
marshall
Need advice - rack mount amps -normal amps ? Jaden Gear, Equipment, Recording & Off Topic 7 10-20-2008 07:40 AM
Car Audio Amps vs. Guitar Amps Jeff Gear, Equipment, Recording & Off Topic 8 09-01-2003 07:47 AM
50W amps vs. 100W amps kennydoe Gear, Equipment, Recording & Off Topic 13 02-18-2003 02:50 PM
Can someone explain to me power amps and pre amps? BrianH Gear, Equipment, Recording & Off Topic 12 06-27-2002 11:40 AM
Amps, amps and more amps... - Suggestions...there are too ma carlos seo Gear, Equipment, Recording & Off Topic 4 05-17-2001 01:53 PM
