Help Choosing a Delay Pedal - Jemsite
post #1 of 7 (permalink) Old 06-22-2006, 10:22 PM Thread Starter
I need help choosing a delay pedal guys. I've been looking at a lot of different ones and they all have their pros and cons. Here's a list of my stuff I've been thinking of getting:
Keeley/Ibanez AD-9
This pedal sounds really cool. It's analog, it's true-bypass and it's got a cool little feature where the stock stockswitch is used for feedback/occilating delays. I like it because it's small and can use a voodoo labs power block.
Line 6 Echo Park
This pedal also sounds really cool. I like it for the immense power that it packs, all the delays and modes you could possably want with a tap tempo. Problem is it's Line 6, it's the EMG of the amp/effect world "it's sounds too digital... it's too lifeless blah blah blah even the analog settings sound too digital". Another problem is it uses a Line 6 power connector, while the voodoo labs power pack +2 says it'll power Line 6 pedals, a lot of people seem to be getting lots of noise and stuff if they don't use the OEM adaptor.
Visual Sound H2O Liquid Chorus/Delay
This pedal is freakin cool because it's 2 pedals in one. You get true analog chorus and a analog voiced digital delay, each channel can be used independently or together. I like it because it's cheap (I can get it for less than $100) and it sounds pretty good. My concern is, no true bypass and made in China (cheap parts).
Analog Man/Boss DD-6
Why not add the tride and true in here? Modified with a switch to make it sound more analog'y. My only concern? Everybody uses it. I wanna sound slightly different ya know?
RSVampire is offline
post #2 of 7 (permalink) Old 06-22-2006, 10:54 PM
Re: Help Choosing a Delay Pedal
I have a Line 6 DL4 (the Echo Park's big brother) I absolutely love it. I sold off my rack delay because this is so cool. I can have a long digital delay for solos, a slapback Roland Space Echo type sound for cleans, and a analog tube echo type sound for spacey 60s rock tunes. It has so many delays, and options. You should give it a look, plus it is true bypass, and has tap tempo. It also is stereo so if you have a stereo setup (rack users), it can accomodate.
speedy mcfeely is offline
post #3 of 7 (permalink) Old 06-23-2006, 02:28 AM
+1 on the AD-9
Shredder87 is offline
post #4 of 7 (permalink) Old 06-23-2006, 10:05 AM
The echopark sounds great. Mine was quiet with the pedal power 2. Keep in mind that it wants an instrument level signal, so if you are going into an effects loop with it, make sure its instrument level.
Rudy is offline
post #5 of 7 (permalink) Old 06-23-2006, 10:08 AM
I think it depends on how you're gonna be using it. Are you going to be doing more reverb/echo noises to make your sound fuller or are you going to be using it for more extreme purposes? I think the AD 9 would be better for natural sounding echo-type usage, but the DD6 for the more "out there" stuff.
ChopTart is offline
post #6 of 7 (permalink) Old 06-27-2006, 08:59 PM
I'd go with the Line 6 Echo Park. I have it and it's amazing, especially for a digital unit. The analog mode sounds pretty darn real too.
IMO, you get WAY more bang for buck buying the Echo Park versus the AD-9 or the DD-6. My friend has a DD-6, but actually sold it to go out and get an Echo Park after having played around with mine.
As much as I tend to stray away from Line 6, the Echo Park is a winner.
waylay00 is offline
post #7 of 7 (permalink) Old 06-27-2006, 10:55 PM
The Line 6s DO sound good.
Albeit, they're a little heavy, if you're transporting your pedal board.
I have an AM modded DD3 and its everything I could want in a delay.
A toggle switch for analog tone, yet all the delay times digital offers.
And there's times when I need a crystal clear delay tone also, so I use the stock setting.
Small, bulletproof pedal.
HIS ROYAL DARKNESS is offline
delay pedal , pedal board , toggle switch , voodoo lab , voodoo labs
boss delay pedal :X wallie! Gear, Equipment, Recording & Off Topic 4 04-22-2006 08:51 AM
What Delay pedal to buy? carlos grijalva Gear, Equipment, Recording & Off Topic 18 09-07-2005 09:23 AM
Opinions - Best Analog Delay Pedal? HIS ROYAL DARKNESS Gear, Equipment, Recording & Off Topic 5 07-11-2004 04:13 PM
delay pedal for guitar FinnJ Gear, Equipment, Recording & Off Topic 4 06-23-2003 01:23 PM
Looking for a Delay Pedal - Any suggestions? carlos seo Gear, Equipment, Recording & Off Topic 16 02-05-2001 06:05 PM
