Help with freeze pedal power - Jemsite
post #1 of 12 (permalink) Old 06-08-2011, 03:20 AM Thread Starter
I got a freeze pedal from a friend but didn't get the power supply.
The site says it comes with a 9.6 200mA. It also says you just need 9vdc with 140mA
If I buy one from the store I know to get 9 or 9.6 for volts. Is mA the same as 2.0A?? 2.0A = 200mA? or 0.2?? I am confuse
-Rhaab is offline
post #2 of 12 (permalink) Old 06-08-2011, 03:51 AM
Reviews: 64
Re: Help with freeze pedal power
are you really asking if mA = A?
LOL
Yep they're the same, they gave them different names because they thought......hmm people will get confused about it!
6fingers is offline
post #3 of 12 (permalink) Old 06-08-2011, 03:58 AM
Reviews: 120
Wrong.
mA is milliamps. 1000 milliamps = 1A
LonePhantom is offline
post #4 of 12 (permalink) Old 06-08-2011, 12:48 PM
Reviews: 12
Originally Posted by LonePhantom View Post
Wrong.
+1. And I believe you can still run off a 2000mA (2A) power source, you just won't use near as much power as it's rated for. Someone do please correct me if i'm wrong; but I do use a pedal rated at 250 mA with a 1200mA power source and it works fine.
GroovyTubes is offline
post #5 of 12 (permalink) Old 06-08-2011, 09:26 PM
Reviews: 120
Yes, its always best to have a supply with more milliamps/amps then you need. The reason being, as you get closer to the rating the more noise you may get.
post #6 of 12 (permalink) Old 06-08-2011, 09:53 PM
Reviews: 3
hmm, interesting. A while back when i bought my powerall kit for pedals, (which is 2000ma)i plugged my weping demon wah into it, and when i had it on toe up, it made a really bad hissing. i had the same problem with the 1spot, so i tried the power all. anyways, i had an extra 9 volt around, plugged it in, and its fine now. Not sure why it does this
IBZshredder is offline
post #7 of 12 (permalink) Old 06-09-2011, 10:47 PM
jb4674's Avatar
Reviews: 18
I've never been a fan of the 1spot. IMO, that's like using the Grisswold method to power up devices....
Jimmy
jb4674 is offline
post #8 of 12 (permalink) Old 06-10-2011, 12:10 PM
Reviews: 59
I actually think the noise issue has a lot to do with the building wiring where you're plugging in. You may be more likely to get noise the closer you are to the mA that are being used, I'm no electrician. However, I use a one-spot at home and have had no issues with noise and it's powering 8 pedals at the moment with no more noise than when I use 9v batteries or plugging directly into the amp with no pedals in the chain.
That said, I've played other places where I had to go with batteries because I would get a lot of noise with any AC adapter (one spot and individual) that I tried.
smooth55 is offline
post #9 of 12 (permalink) Old 06-17-2011, 06:57 PM Thread Starter
I got a 9v 800ma adapter (nexxtech) and it works fine, thought i broke the pedal or needed a different tip cause it didnt work but turns out i just had to change the tip the other way cause its supposed to be negative when i had it positive
-Rhaab is offline
post #10 of 12 (permalink) Old 06-17-2011, 11:46 PM
Reviews: 12
PLEASE check before you just plug some power adapter into your pedals. Most have built in security measures against switching polarity (like fuses), HOWEVER, some older pedals and even some cheaper pedals may not have a fuse. If that is the case you will burn the circuit board up.
Use this picture as a guide:
In this photo, the left side of the photo means the center is positive...on the right side, the center is negative. Make sure your power adapter matches the polarity on your pedal...just to be completely safe
post #11 of 12 (permalink) Old 06-18-2011, 05:06 AM
Reviews: 11
Jimmy
True, but I have had the same 1 spot for 7-8 years, no problems yet!
linuxpenguin is offline
post #12 of 12 (permalink) Old 06-18-2011, 05:08 AM
Reviews: 11
voltage = amps x resistance
-> amps = resistance/voltage
if resistance is kept constant and amps goes up....
that means you have a corresponding voltage DROP, using less power, but its far more dangerous to use it like that.
F.E.A.R. freeze; PS3 D.M.RG7620 Off-topic / Miscellaneous 0 04-05-2011 10:19 PM
WTB: Voodoo Lab Pedal Power 2, BBE Supa Charger or MXR CAE Power System Levi79 Classified Ads: Guitars and Gear 2 12-23-2010 01:06 AM
Voodoo Pedal Power/Pedal Train shredder1 Gear, Equipment, Recording & Off Topic 2 08-22-2010 02:01 PM
Voodoo pedal power the way to go to power pedals ? Silverburst Gear, Equipment, Recording & Off Topic 9 06-22-2009 02:43 PM
Voodoo labs pedal power 2 plus or normal power strip? SilverSurfer2 Gear, Equipment, Recording & Off Topic 2 05-21-2009 11:20 PM
