Help identifying this tremolo - Jemsite
post #1 of 4 (permalink) Old 03-17-2017, 06:35 AM Thread Starter
Hey fellas, I recently purchased a swirled jem body off ebay, it came loaded with EVO pup set and some sort of floating tremolo installed. However not sure exactly what tremolo this is. It has Ibanez branding on it, "Licensed Under Floyd Rose Pats." and also says "LITIAN CENIURY" on the block that sits in the cavity. Anyone know what this is? The plan is to install an OE tremolo in the body in place of this, however not sure if its compatible. Many thanks
Pictures below,
https://s14.postimg.org/vo283svy7/image.jpg
https://s28.postimg.org/fs8e8xwff/image.jpg
Halrey is offline
post #2 of 4 (permalink) Old 03-22-2017, 06:10 AM Thread Starter
Re: Help identifying this tremolo
Bump. Can anyone help? Would it be easier to show you the guitar body/cavity to see if an Edge tremolo would be compatible/fit? Thanks guys
Halrey is offline
post #3 of 4 (permalink) Old 03-22-2017, 06:28 AM
Could be SLT 101, ILT1 or TRS,
If you asking for changing tremolo to edge or other,
cavity dimension is more important because, tremolo could be changed before, and present one doesn't have to be original from body.
peromucho7 is offline
post #4 of 4 (permalink) Old 03-22-2017, 07:36 PM
Reviews: 120
It does look to be a lower end Ibanez bridge. I wouldn't be surprised if an OFR or Gotoh would fit right in, but as previously mentioned, the cavity dimensions are the important part here. Measure that, and compare against dimensions of your preferred replacement bridge(s) and work from there.
LonePhantom is offline
floyd , ibanez , project , rose , tremolo
Identifying Ibanez Tremolo Jaylaggs Archived Topics and Common Questions 1 01-09-2014 05:47 AM
Wtb: jem back tremolo cavity plate and edge tremolo arm JemSearcher Classified Ads: Ibanez JEM/UV Guitars 0 01-26-2012 11:17 PM
Is the Edge-Zero II Tremolo a good tremolo system dburn42 All Other Guitars (including Prestige) 6 05-30-2011 11:12 AM
PRS tremolo vs. Floyd Rose pro tremolo bjamin86 Tech: Setup, Repairs and Mods 5 01-25-2010 10:27 AM
Help identifying tremolo "shim" part mr.death Tech: Setup, Repairs and Mods 14 02-26-2008 05:04 AM
