Help me choose an amp! - Jemsite
post #1 of 17 (permalink) Old 06-12-2011, 08:02 AM Thread Starter
Reviews: 20
Hi guys!, I'm looking to buy my first tube amp in near future.
I'm looking for amp that sounds good on bedroom volume, but also loud enough for band practice session.
I play two kinds of music, one is blues, so it must have good clean/break up sound. (Big S.R.V Fan)
Second is hard rock, so it must be capable of saturated hi gain sound with tight low end for rhytm, and good sustaining, harmonically rich lead tone.
I really like the lead tone of Gary Moore (R.I.P) in the song "blues for narada", and "cold day in hell". That might give you better idea what I'm looking for.
I never owned a tube amp before (poor me..!), so I don't know yet what to expect (maintenance, realiability, etc.), I prefer an amp that is self-biasing, or fixed bias, because I don't know a thing about electronics, and I don't know where to find a tech where I live.
After playing for 5 years, I've owned numerous multi-fx pedal (Zoom 707, Korg AX1500, POD XT Live, BOSS GT-8, Tonelab LE), on all of them, I tend to favor the british amp models, my favorite is the "plexi variac" on the Line6 POD.
My main guitar is a Fat Strat style with alder body and duncan pearly gates. I also have an Ibanez AR300 with duncan TB-5.
I'm willing to spend amount equivalent to 2000$ maximum
Right now I'm thinking either small low wattage tube combo, in particular the cornford carrerra, or a high watt amp that able to sound good at low volumes (mesa mk v?) Which one do you think will suit me best?
Any suggestion is highly appreciated! (pardon my english!)
bowie8889 is offline
post #2 of 17 (permalink) Old 06-12-2011, 09:25 AM
Re: Help me choose an amp!
I have a Mark V and it definitely covers your requirements other than being just over $2000. However, it's pretty complex in that it takes a while to dial in your sound. It's an awesome amp that covers an insane amount of ground but be prepared to spend some time with it. It does quite well at low volumes even on the 90 watt setting. I live in an apartment and play mostly after my 2 toddlers are asleep . That being said though, I had trouble getting the sound I wanted at low volumes through Black Shadows in my 2x12 (I mention this in case you get the combo which comes with a Black Shadow). I swapped in two V30's yesterday though and it sounds much better. This is a good example of how low you can play it: http://www.youtube.com/watch?v=dCm7-G1zlWI
You might also want to take a look at the Mesa TA-15 which does both British and American sounds very well. Either way, I would try to find them locally and actually play them.
EvilEmuOfDoom is offline
post #3 of 17 (permalink) Old 06-12-2011, 11:51 AM
Reviews: 59
Be aware that you'll have trouble really cranking any wattage tube amp and keeping it at or below talking levels. If you need quiet, stick to solid state stuff (for practice) and then crank your tube amp when you're jamming out.
I'd look at the Blackstar Venue series as they are in the marshall vein without the marshall price tag and would be a lot less than your allotted budget.
smooth55 is offline
post #4 of 17 (permalink) Old 06-12-2011, 05:42 PM
Reviews: 120
Not entirely true. I use my Blackstar HT-5 for home and band, and it sounds awesome for both. Plenty loud for gigs, rehearsal and home practice.
To the OP, I'd suggest a Blackstar HT-20, but try a HT-5 and see if it will do what you want at high volume. I don't use the clean channel with my band, just roll the volume down on my guitar.
LonePhantom is offline
post #5 of 17 (permalink) Old 06-12-2011, 05:43 PM
FYI - fixed bias doesn't mean that it's not adjustable. It's usually the opposite. Cathode biased amps do not require bias but they sound different and are less common than fixed bias. Also, cathode biased amps are more for bluesy sounds since they compress more than fixed bias amps which makes them sound more creamy than fixed biased amps. Since you want tight low end for rhythm, that rules out cathode biased amps. Some manufacturers (like Mesa) use fixed bias which is preset to certain value so they can force you to buy their output tubes only, but majority of fixed bias amps have bias pot somewhere.
The bottom line is, if you want a fixed bias amp that does not have a bias pot you're pretty much stuck with mesa. Which is not a bad thing if you can afford one. If Mark V is not an option, express 5:50 is also a nice amp.
Cheers
bancika is offline
post #6 of 17 (permalink) Old 06-12-2011, 06:36 PM
Reviews: 98
Take a look at the Epiphone Valve Jr.
AlaskaBat is offline
post #7 of 17 (permalink) Old 06-12-2011, 06:42 PM
how does that fit?
bancika is offline
post #8 of 17 (permalink) Old 06-12-2011, 07:07 PM
Reviews: 98
It's a 5 watt class A tube amp, and fits right in with the OPs requirements. Plus, it sounds great...
post #9 of 17 (permalink) Old 06-12-2011, 09:07 PM
Reviews: 12
Mark V, Mark V, Mark V.
Switchable 90w, 45w, and 10w should be able to cover a whole range of volumes from bedroom to stadium (plus give you a little extra possibility for tube breakup for blues) PLUS there are some fantastic sounds to be dialed in with the given time. However, this beast has a total of 12 tubes (4x6L6 (or 4xEL34), 7x12AX7, 1x5U4)...which can deal a pretty big blow when it comes time to change out the tubes. That's about the only downside i've found.
GroovyTubes is offline
post #10 of 17 (permalink) Old 06-13-2011, 02:59 AM
Second hand Genz Benz Black Pearl 30, switchable to 15 or 7.5 watts. Footswitchable boost, EL84's self-biasing.
Or how about a used plexi and a good OD pedal?
guitarnoize is offline
post #11 of 17 (permalink) Old 06-13-2011, 04:08 AM
Or a used Plexi clone, Ceriatone? If you get a 50 watt you can fit a Variable Voltage Regulator to turn the power down without losing the tone.
post #12 of 17 (permalink) Old 06-13-2011, 04:51 PM
Matchless Lightning. Best amp I've ever had. And I've owned a few!!!
quiqueguitar is offline
post #13 of 17 (permalink) Old 06-14-2011, 12:52 AM
Reviews: 11
Vox NightTrain and a decent OD pedal
jbouxa is offline
post #14 of 17 (permalink) Old 06-14-2011, 01:33 AM
Reviews: 11
Ive been loving hughes & kettner lately.....the TriAmp MK1 is a great amp with plenty of gain and the cleans are sweeeeet and sexy. They used to be really expensive too but since the MK2 came out, the price dropped. You can find them around for about $900 used. And made in america too (back says Cory Illinois to be exact). Only problem is i dont know how well it holds up at low volumes
Oh, and its one damn good looking head
D.M.RG7620 is offline
post #15 of 17 (permalink) Old 06-14-2011, 02:24 AM
Reviews: 98
When are you going to snag your old man's B-52???
amp suggestion , gary moore
Help me choose an S... oilpit All Other Guitars (including Prestige) 13 05-14-2010 07:53 AM
What to choose?? kshands All Other Guitars (including Prestige) 19 03-28-2010 03:53 AM
still can't choose amp.... carlos grijalva Gear, Equipment, Recording & Off Topic 20 12-06-2005 01:00 AM
Could u help me choose ? Requiem All Other Guitars (including Prestige) 4 02-18-2004 03:47 PM
Which one should i choose Zenabi Gear, Equipment, Recording & Off Topic 2 01-05-2003 09:10 PM
