help me get a good tone - Jemsite
post #1 of 9 (permalink) Old 08-25-2003, 07:06 PM Thread Starter
Hey i need some help here..
I want a good tone like a vrtuoso sound.. petrucci, vai, satriani, yngwie, etc. mostly petrucci cuase that is my kinda style. but i can't seem to get anywhere close to a good sound. Right now i'm using a boss gt6 and a Marshall JCM2000 TSL. Personally i think the marshall amp distortion sucks. It's to vintagy for me. so i bought the gt6 to try to improve my sound.. but it sounds like way too digital not really what i'm looking for. I've tried Mesas and i really think their distortion is very unrefined as well. Is it even possible to get a really great sound through just an amp? cuase i've had no luck.
I'm getting so damn frustrated i'm thinking of throwing all my **** in the garbage and callign it a day.. but i really don't wanna do that. so i've been reading up on effects loops and processors and amps and all that stuff. I wanna hear what you guys think on amps to use settings. effects (rackmount, stomp boxes or processors), effects loops or straight input, blah blah blah, basically anything you can think of to help out with my sound. money isn't really an issue with buying things.
i have a J custom RG8527 which i'm very happy with so that isn't a problem. Any info would be GREATLY appreciated.. thanks
adam
adamcbest is offline
post #2 of 9 (permalink) Old 08-25-2003, 10:09 PM
I'd suggest a POD. If it ain't got it, you don't need it.
Keep in mind though that most of your tone happens between your head and the ends of your fingers.
l8r g8r is offline
post #3 of 9 (permalink) Old 08-25-2003, 11:42 PM Thread Starter
haha yeah dude.. i can play well. no problems there. I'm just extremely picky with my tone.
post #4 of 9 (permalink) Old 08-26-2003, 12:08 AM
ScottB's Avatar
Try a Voodoo Lab Sparkle Drive. It is the best sounding overdrive pedal I've ever had in my rig. It has a classic TS-808 tone for its overdrive and adds a clean boost knob on top of the OD. It almost sounds as if you're playing through 2 amps at once. There's nothing in the GT-6 that will give you this sound. I use mine with a Carvin X100-B head (similar sounding to a JCM800, but with active eq controls.) On the pedal, I set the distortion at 2 o'clock, the tone at 10 o'clock, clean boost at 1 o'clock and volume level at 2 o'clock. Using the numbers on the amp controls: gain = 6, master volume = 3 - 5 with the lead boost engaged, bass = 7, mid = 5, treble = 5, presence = 7, reverb = 2, graphic eq = off (set to clean channel), power level at 50% (50 watts).
For chorus, flange and phaser effects the Line6 MM-4 Modulation Modeler pedal is nice. For delay effects, the L6 DL-4 is awesome sounding as well.
ScottB is offline
post #5 of 9 (permalink) Old 08-26-2003, 06:45 PM
So can Steve Vai, but Frank Zappa once told him he sounded like an electric ham sandwich. I'm talking about the Zen-like nature of tone, grasshopper. Didn't mean to say you couldn't play.
l8r g8r is offline
post #6 of 9 (permalink) Old 08-27-2003, 09:00 AM
OME
Reviews: 6
Adam
If your doing a bands coversongs and need to be versatile with your sound a processor like POD or Valve FX is a good choice, but to make
your own original sound WILL BE an adventure as I found out in the last
few months.
I suggest finding the type of distortion box that suites YOU first.
And begin painting your sound from there by touching it up with
your Rev/Dlys/Chorus/Flng and add your trickbag effects as far as
Whammy/Wah and such. Stomp boxes have a certian presence that
processors don't have and a using a processor to much can make for lazy fingers
OME is offline
post #7 of 9 (permalink) Old 08-27-2003, 03:55 PM
Try turning your Tone-pot to 6 or 7...and yes that's not much advice I know...
Texter is offline
post #8 of 9 (permalink) Old 08-27-2003, 04:35 PM
Re: help me get a good tone
Ok, I'm playing a 7620 into a TSL head, and I had the same problem at first, and was also looking for a Petrucci, g3-era sort of tone. Here's the settings I came up with, for a lead sound:
Gain: 5
Treble: 3
Mid: 7
Bass: 4
Tone Shift: off (I don't know if the DSL heads have this- it's a mid schoop control that sounds like **** whne you enguage it)
Presence: 9
deep: on
volume: 6
VPR (variable power reduction, simulates 25 watt mode): 0n
You gotta have pretty solid finger control to get this to work, which I don't have yet (I'm a bit sloppy), but this sound KILLS with my 7620, particularly on the neck pickup (the bridge is still a touch bright to my ears, but maybe that's good). It's got a similar "feel" to JP's G3 tone, but a slightly different shade: a little warmer, not quite as dark. It's taking me a little while to get used to the lower gain, as i'm a fairly sloppy guitarist, but it's coming. This is a fairly loud setting, of course, and the power amp grind is definately part of the tone... but with the volume most of the way down it still works pretty well, it's just not quite as smooth.
I'm suprised you consider the DSL/TSL series as "too vintage"- the Lead mode, especially, on my TSL is a VERY modern sounding distortion, with a thick low end, and a slightly scooped, darker sounding lower midrange.
-D
Drew is offline
post #9 of 9 (permalink) Old 08-27-2003, 04:42 PM
Or, you could not try to clone the original tones, and just settle on a "band" sound to play everything with, giving your band more of a personal identity, and differentiating you guys from a walking, talking jukebox...
It's not your fault, it's just the Line6 guys who are doing theiur damndest to get cover bands to think this way...
-D
Drew is offline
amp distortion , frank zappa , marshall amp , neck pickup , overdrive pedal , power amp , steve vai , stomp box , voodoo lab
Getting a good tone direct jordanstreet Gear, Equipment, Recording & Off Topic 5 05-11-2008 10:19 PM
Good guitar tone nabeelm Gear, Equipment, Recording & Off Topic 4 08-19-2004 10:11 AM
How can i get a good tone out of My vooduvalve? JEM10th Gear, Equipment, Recording & Off Topic 2 07-02-2003 10:27 AM
Getting good gain out of the Legacy - Good tone, no doubt, b floydJ Gear, Equipment, Recording & Off Topic 25 08-03-2001 06:35 PM
Good distorted tone.... yuza Gear, Equipment, Recording & Off Topic 41 07-16-2001 12:17 AM
