Help with my rig... - Jemsite
post #1 of 6 (permalink) Old 10-24-2007, 05:16 PM Thread Starter
Question Help with my rig...
Hi Everybody!!!
I hope somebody can help me, I got these stuff but I dont know what kind of output do I need, I heard that to run the Mesa Pre Rec live I need a Power Amp...
Furman Power Conditioner
TC G-Force
Mesa Boogie Rectifier Recording Pre
I want to do some live gigs, but what kind of Output suits me better? Do I need a Power Amp for the Rec Pre? what is best?
post #2 of 6 (permalink) Old 10-24-2007, 06:45 PM
Reviews: 12
Re: Help with my rig...
you definitely need a power amp and a matching cab to go with that setup. To get the full-on Recto tone with that Pre, you might as well get a 2:100. However, you can find other tube power amps of the same or lesser wattage to give ya a Recto tone with a punch that would only be defined by which power amp is used.
Not sure what your budget is but ya can check into the older Mesa power amps [2:95, 3:95] or a 2:90 as they have the Simul-class system that makes the guitar sound "3D". If 90W is a little bit too much, ya can look at a Mesa 50/50 [or 2:50]. If Mesa isn't up your alley, ya can check up VHT poweramps.
As for the rest of the gear, you'll need a midi pedal for the G-Force and a midi switching system [like a GCX] to control the amp and whatever patches you have on there
Reg
reguv760 is offline
post #3 of 6 (permalink) Old 10-25-2007, 08:25 PM
Reviews: 3
I've got a VHT 2/50/2 and it blew away my old JCM800. Great amp. If you want more low end go for the 2/90/2.
You won't be disappointed in VHT. Amps or cabs.
BTW, also had a G-Force. Great effects and killer pitch tracking. The secrets are in the Mods and Matrix.
finstah is offline
post #4 of 6 (permalink) Old 12-08-2007, 12:34 PM
If you can find one, a used MosValve power amp is a great sounding bargain (80 watts per channel) for a rack-based guitar rig. The VHT is great but will cost you.
albee1952 is offline
post #5 of 6 (permalink) Old 12-10-2007, 12:26 PM
got one of those old mosvalve amps. great sounding guitar amp. not super clean, but guitar based power amp.
rich
rty13ibz98 is offline
post #6 of 6 (permalink) Old 12-13-2007, 12:26 PM
You'll need a power amp and a cab. I'd actually recommend keeping an eye out for the VHT stuff, or actually a rivera TBR-3 or TBR-5, as they are both awesome power amps that noone seems to want, and can be had cheap, and it's rivera, so it's built extremely well.
7 Dying Trees is offline
furman power conditioner , mesa boogie , mesa boogie rectifier , mesa power amp , midi pedal , power amp , power amps , rivera tbr , sounding guitar , tube power amp , valve amps
