Help needed w Audiophile and Cubase! - Jemsite
post #1 of 3 (permalink) Old 08-27-2003, 12:32 PM Thread Starter
I have Audiophile 2496 and SB Live! Platinum on my PC. I'm trying to record with Cubase. Both cards are working just fine and I can get S/PDIF signal from my BOSS GT-6 to my PC and hear the guitar from my monitor speakers.
Problem:
In Cubase's device setup I can only get sound from "ASIO DirectX Full Duplex Driver" and "ASIO Multimedia Driver" both with horrible 400ms (estimate by ear) latency. The one I guess I should use is "M-Audio Delta ASIO" but I get no life whatsoever in Cubase with that setting (VU meters dont react). Why I guess it should be the correct one is because with that driver the "Control Panel" button opens my M-Audio panel as is said on Audiophile manual.
If anyone can give step by step instructions for recording with Cubase from Audiophile S/PDIF interface, I'd be happy. Both manuals have been no use whatsover.
PekkaM is offline
post #2 of 3 (permalink) Old 08-29-2003, 01:04 AM Thread Starter
I want to add that I can get sound recorded through analog input so it probably is something S/PDIF related...
PekkaM is offline
post #3 of 3 (permalink) Old 08-29-2003, 07:15 AM
Well i dunno about the SPDIF, but i had analog problems, that might have the same solutions as your digital ones.
I have 2 Yamaha Cards DSP 2496 and SWG1000, if i'd select from the multimedia driver panel the built in setup that cubase has for one of the cards, it doesn't work, so here's what i did.
Select Custom from the pannel, the detect everything manually, then run simulation.
Other things to check out:
1. In the Multimedia pannel, make shure the appropiate inputs and outputs are selected
2. You might have to open the digital input somewhere, but this might not be true just a guess
juiceofvenus is offline
audio delta
M-Audio Audiophile... red5 Off-topic / Miscellaneous 0 10-03-2005 10:07 PM
Windows 2000 prof. and Cubase SL help needed! Kev Brigden Gear, Equipment, Recording & Off Topic 0 10-17-2004 10:36 AM
Cubase help needed :D Kev Brigden Gear, Equipment, Recording & Off Topic 7 08-27-2002 09:21 AM
Audiophile 2496 satchman888 Gear, Equipment, Recording & Off Topic 12 07-23-2002 09:32 PM
BR8 to Cubase - Having trouble recording BR8 to Cubase MikeyJ Gear, Equipment, Recording & Off Topic 4 02-28-2002 07:01 PM
