Help with ReValver MKIII and USB interface - Jemsite
post #1 of 5 (permalink) Old 08-23-2011, 10:40 PM Thread Starter
I have been experimenting with the Revalver standalone today on my laptop and I have an idea what I'd like to do but not exactly how to do it.
Essentially, I would like to use ReValver as my home practice amp. I'd like to pass my guitar through an ASIO interface to the ReValver software and then output via ASIO back to through the interface device and finally run it to the effects return on my amp.
I have a Tonelab that has USB interface capability, and supposedly it can send signal to the computer via USB, receive it back via the same USB and output to an amplifier, and it actually works, EXCEPT for the fact that the output on the Tonelab really doesn't like having the USB cable plugged in. Even with the Tonelab turned off, if it is plugged into the computer via USB, there is a loud hum that cannot be tweaked out. It has nothing to do with ReValver. It's as if plugging in the USB interferes somehow with the output from the TL.
Is there something else I can employ as an interface which will work that way? I saw that the M-Audio Fast Track MKII has the guitar in and a headphone jack. Can the headphone jack be run to the effects return on my amp and give me what I'm looking for?
Or is there a better way to do this altogether?
bossfrog is offline
post #2 of 5 (permalink) Old 08-24-2011, 08:51 AM
jb4674's Avatar
Reviews: 18
Re: Help with ReValver MKIII and USB interface
I'm afraid that's going to be a tall order. I have the ability to monitor my GT-Pro via usb and when I connect it to my laptop in conjunction with the Boss Editor software, the same hum noise kicks in allowing me to hear my laptop's cpu, screen saver, etc.
The only possible way to do this might be to buy a low-latency usb card with a good chipset so you can try it and see if the problem continues.
Personally, I think the Revalver software was intended to be used to re-amp your guitar track with one or more of the models in Revalver while inside a DAW, not the other way around (i,e., outputting back to your amp as an effect). Although I could be mistaken, that's how I understand it to work.
Jimmy
jb4674 is offline
post #3 of 5 (permalink) Old 08-24-2011, 04:51 PM Thread Starter
I've seen that a lot of people are adopting ReValver as their live rig using such an arrangement so I know it's viable. It seems that a lot of people are using the Line6 Toneport UX2 for the interface, so I'm going to try one of those. A poster on the M-Audio forum said it sounds like a ground loop between my amp and my computer, so I'm going to put my amp on the same power strip as my computer. I'm told that's the easiest way to rule that out.
bossfrog is offline
post #4 of 5 (permalink) Old 08-25-2011, 12:42 AM
Reviews: 34
I have what may sound like a really stupid question for you.
Have you tried sitting further away from the monitor?
It worked for me.
nickcoumbe is offline
post #5 of 5 (permalink) Old 08-25-2011, 11:11 PM Thread Starter
It worked for me.
Yeah, it wasn't interference. Turns out it was a ground loop. I switch outlets with the amp and the problem was solved.
bossfrog is offline
interface , revalver , tonelab , usb
Can I sell my Peavey MKIII software to someone else? SilverSurfer2 Gear, Equipment, Recording & Off Topic 1 07-17-2010 06:16 AM
Peavey Revalver Big Job Gear, Equipment, Recording & Off Topic 0 07-15-2009 09:28 AM
Peavey Revalver - MKIII Big Job Gear, Equipment, Recording & Off Topic 2 07-17-2008 01:59 PM
My Mesa Boogie MkIII tone from 1991 Darin Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 10-18-2007 10:00 AM
ReValver and Audigy... Kasper Kowalski Gear, Equipment, Recording & Off Topic 0 04-24-2003 09:31 PM
