how to attain power tube saturation with a preamp and power amp? - Jemsite
post #1 of 9 (permalink) Old 09-06-2010, 08:25 PM Thread Starter
i have a tube preamp with a master volume and a power amp with a level knob.
should i crank the master volume to get power tube distortion or the level knob on my power amp?
-Henry
esppse is offline
post #2 of 9 (permalink) Old 09-06-2010, 08:56 PM
Re: how to attain power tube saturation with a preamp and power amp?
What king of pre-amp & power amp are you running? You should be able to run the preamp with a good hot(almost cliping) signal. Presence should help, are you running a distortion pedal in front? That my help to boost a max. output. There are few different ways , depends what you have to work with. JJ tubes(eurotube) are my fav. for high gain.
Guiatarded is offline
post #3 of 9 (permalink) Old 09-06-2010, 10:13 PM Thread Starter
im using a lee jackson GP-1000 into a peavey 50/50. no pedals in front, but i do have a couple overdrive pedals in my storage lol. whats the best way to get that saturation?
esppse is offline
post #4 of 9 (permalink) Old 09-06-2010, 11:07 PM
elcid's Avatar
The only way to really get it is to turn it up and make the power tubes work. You could throw an attenuator in there, but I had a THD Hot Plate with my Marshall 1959 SLP and the attenuator did keep the volume down, but it sucked all the life out of the amp and made it sound thin.
Putting a pedal infront of the preamp will just boost the signal going into the amp and make the preamp tubes work harder, it will not give you power amp saturation.
elcid is offline
post #5 of 9 (permalink) Old 09-06-2010, 11:19 PM Thread Starter
which do i turn up though? the master volume or the power amp's volume knob?
or both? idk lol
esppse is offline
post #6 of 9 (permalink) Old 09-06-2010, 11:27 PM
elcid's Avatar
You want the power amp tubes to work, so turn up the power amp.
The pre amp just handles your tone shaping and boosts the guitar signal a little bit, the majority of your volume is from the pre amp.
elcid is offline
post #7 of 9 (permalink) Old 09-06-2010, 11:47 PM Thread Starter
ah i see, unfortunately it be sooo damn loud
there are 3 volume knobs in all
the Preamp Volume to control how much guitar signal goes into the preamp tubes/aka preamp gain?,
the Preamp Master Volume to control how much signal goes into the power amp/aka saturation?,
the Power Amp Volume to control how much output goes into the speakers/aka loudness?
but i thought if you put more signal into the power tubes, you get saturation (thats the master volume right?)
esppse is offline
post #8 of 9 (permalink) Old 11-11-2010, 06:12 AM
technically your right but it doesn't sound very good
what you want is clipping (the signal tops are clipped off, making a sine wave into a square wave and also bring the decay signal up to the sustain level making a seamless transition)
and these to things do not occur until each stage is at full power
the best way to imitate this is buy a ts-808 and put your gain on 4-6 and set volume where you want it
it's as close as you'll get
Manticore is offline
post #9 of 9 (permalink) Old 11-12-2010, 09:21 AM
You need to Max out your power amp, as 'Cid said, and then play with the rest. by opening up the power amp, you kick the headroom way up. your pre will induce clipping, your master volume will most likely add the kind of noise you don't want where things shouldn't be clipping. It's funny how some forms are desirable, yet between stages, you want more signal integrity. Manticore is totally spot on. Drive the front end of the amp with a TS or BB preamp by Xotic. You'll get a more musical and defined tone.
bammbamm is offline
preamp power amp
FS: VHT 2/50/2 power amp and VHT GP3 preamp ALL TUBE sfx70 Classified Ads: Guitars and Gear 2 09-17-2010 08:11 PM
Preamp, power amp... HELP Metal Tiger Gear, Equipment, Recording & Off Topic 13 06-04-2007 10:19 AM
Power tube tone vs. SS tone (not preamp) revsharp777 Gear, Equipment, Recording & Off Topic 20 06-08-2005 01:13 AM
converting US preamp to take Aus power? Ki swordsman Tech: Setup, Repairs and Mods 5 07-07-2003 07:47 PM
preamp+tube power amp=head? - combine a manufacturer's "part ns9 Gear, Equipment, Recording & Off Topic 6 03-03-2002 06:06 PM
