how do you make a fenders dis sound better - Jemsite
post #1 of 14 (permalink) Old 08-01-2005, 11:34 PM Thread Starter
Question how do you make a fenders dis sound better
I have a fenderhot rod delux and the dis is horible any suggestions instead of getting a pedal? (Oh and i cant turn the volume to high so f that idea).
metalguitarist7778 is offline
post #2 of 14 (permalink) Old 08-02-2005, 12:11 AM
Re: how do you make a fenders dis sound better
well, a boss ds-1 with an overdriver(zw44) . That combo can make a really nice distortion set up.
maybe just an overdriver will do the trick. How old are the tubes in it? may play around with new 12ax7s to see if you can't get something more that you like, if you do get some 12ax7s electro-harmonix or jj are both pertty soild brands.
j.arledge is offline
post #3 of 14 (permalink) Old 08-02-2005, 12:29 AM
Gex
The Hot Rod Deluxe just isnt a metal amp, its a clean/low gain amp.
If you need a metal sound, your best bet is getting a metal amp. Sure, you can try some pedals, but they are not going to sound as good as an amp's distoriton.
Gex is offline
post #4 of 14 (permalink) Old 08-02-2005, 02:44 AM
yeah get a tube half stack or combo from carvin.com
guitarshredder7 is offline
post #5 of 14 (permalink) Old 08-02-2005, 01:53 PM Thread Starter
from carvin ay wellm im not sure this amp is pritty good and i vcould just get a pedal and a thing that letsa you not have to get new batteries for it.
post #6 of 14 (permalink) Old 08-02-2005, 07:59 PM
Make it better by buying a Marshall
JM5150 is offline
post #7 of 14 (permalink) Old 08-02-2005, 08:38 PM
i'd play the marshall before ever getting one. Evrey marshall i have played i didn't like much at all,simple put i hate marshall and feel that they are totally over rated P.o.s. amps .
Saying this i will say that sound is extermly subjective and it is very hard to offer good advice because someone can't just say "you'll love the way this sounds or this pedal is the one for you" it . So in short screw everbody else because they aren't you and dont like the same things as you, play all the stuff you want first hand, it maybe hard but it you are much better off knowing exactly what you need .
i played a digitech death metal today, it gave some alright distortion but it was a bit noise, and out of curiosity i plugged it into a marshall avt 50 combo and it was ok until i turned the pedal off.
post #8 of 14 (permalink) Old 08-02-2005, 08:43 PM
Reviews: 6
yeah i'm not big on marshall either. I actually like fender amps, but then again i'm more of a fusion/rock guy than full blown metal. Either get yourself a good pedal and a dc unit so you can plug it in the wall or get a new amp.
Jemwielder is offline
post #9 of 14 (permalink) Old 08-02-2005, 09:10 PM
I owned a Hot Rod Deluxe for a while - great amp, awesome cleans and great bluesy overdrive. But, it's not a "metal" distortion amp, and there's nothing you can do to it to change it. If you want a more metal distortion, you realyl should be looking elsewhere...
-D
Drew is offline
post #10 of 14 (permalink) Old 08-02-2005, 10:52 PM
If you like Fender amps then have a look for a Prosonic head or Combo.
If you want to keep what you have, (The hot rod delux is a great amp by it's own right) you really need to put one of the many OD pedals in front.
Sanchez
sanchez is offline
post #11 of 14 (permalink) Old 08-03-2005, 07:05 AM
try some overdrive pedals with it, if that still doesn't work, then get a new amp that produces the distortion you like
Solo Hero is offline
post #12 of 14 (permalink) Old 08-03-2005, 11:08 AM
t.t Marshalls are overpriced and not even that good.
ElectriK is offline
post #13 of 14 (permalink) Old 08-03-2005, 07:10 PM
Gex
The new ones are, the JCM 2000's, AVT's and MGs.
But get an OLD original JCM 800 or JMP or plexi, crank it up, put a pedal in front, and they're great.
Gex is offline
post #14 of 14 (permalink) Old 08-14-2005, 12:04 AM Thread Starter
it doesnt matter i just got a vox ad100vt its pritty good
death metal , marshall avt , overdrive pedal
I will make this amp sound brutal \m/ bates Gear, Equipment, Recording & Off Topic 6 12-14-2013 05:00 AM
How to make an amp sound dark? D.M.RG7620 Gear, Equipment, Recording & Off Topic 23 07-26-2012 05:01 PM
How to make your song sound louder... 6fingers Gear, Equipment, Recording & Off Topic 2 04-05-2012 08:43 AM
How to make an Ibanez RG sound fatter? nkrcompany Tech: Setup, Repairs and Mods 5 10-16-2010 05:06 AM
Can I make my RG sound like a Fender Strat? Need some help... Azrael Tech: Setup, Repairs and Mods 25 04-24-2007 01:00 AM
