how to prevent schaller straplock from unloosing? - Jemsite
post #1 of 8 (permalink) Old 08-10-2008, 11:52 AM Thread Starter
Question how to prevent schaller straplock from unloosing?
Is there anyway to prevent my schaller straplock from unloosing itself??
I almost drop guitar once!!
I tryed: oil, vaseline, silicone spray, wd40....
Pascal
modulo is offline
post #2 of 8 (permalink) Old 09-19-2010, 06:16 PM Thread Starter
Unhappy Re: how to prevent schaller straplock from unloosing?
And bigger screws....
ANYONE????
modulo is offline
post #3 of 8 (permalink) Old 09-19-2010, 06:57 PM
Reviews: 57
lock-tite, and make sure you tighten it with a wrench after spraying.
blackspy is offline
post #4 of 8 (permalink) Old 09-19-2010, 09:55 PM
elcid's Avatar
Why would you try lubricants to keep it from working itself loose?
Is it getting loose in the hole (that's what she said), or is it the end that's on the strap?
Try either filling and re-drilling the hole if its on the body end or putting a few tooth picks in there and don't over tighten the screws
elcid is offline
post #5 of 8 (permalink) Old 09-19-2010, 10:01 PM Thread Starter
Talking Re: how to prevent schaller straplock from unloosing?
the screws unscrew itself!! even with glue!!
You are funny elcid!!!
modulo is offline
post #6 of 8 (permalink) Old 09-19-2010, 10:13 PM
elcid's Avatar
If the screws are coming out, then the hole is stripped. Either fill them and re drill them or put a few toothpicks in the hole, snap off the excess and put the screws back in without over-tightening them. Unless your screws are haunted, they aren't unscrewing themselves.
elcid is offline
post #7 of 8 (permalink) Old 09-19-2010, 10:32 PM
Ayrton's Avatar
Yep, toothpicks in the hole, and then a drop of blue Loctite on the lock
Ayrton is offline
post #8 of 8 (permalink) Old 09-20-2010, 06:03 AM
Tank's Avatar
Reviews: 65
Screws on the guitar:
Put Toothpicks in hole, cut everything that extends to the outside with a toenail clippper.
Put Blue Loctite on the screw.
Screw it in gently, do not overtighten.
Let the guitar rest for 24 hours.
On the strap:
Put it together put some CA on it, let it rest 24 hours.
Tank is offline
straplock schaller
Rusting pup's - how to clean up and prevent Erok Tech: Setup, Repairs and Mods 7 08-06-2008 11:45 AM
Quick straplock help yoyo1299 Gear, Equipment, Recording & Off Topic 11 01-11-2008 11:55 PM
Straplock Screw Size AmazinAzian12 Ibanez JEM, UV, JS & Other Signature Models 1 12-22-2006 11:46 PM
dimarzio straplock or schaller? son_of_zion All Other Guitars (including Prestige) 9 09-28-2006 12:34 PM
Help with hardware! - How to prevent gold from coming off? Turrokk All Other Guitars (including Prestige) 7 05-04-2001 03:54 AM
