Humidity/temperature - Jemsite
post #1 of 3 (permalink) Old 07-28-2003, 02:52 PM Thread Starter
Hey
I keep my guitar in a room (in the basement) that has close to 50% relative humidity, and more than 21C/70F degrees...
Is this too much? Whats the optimal conditions for my guitar?
(Sorry if I posted this in the wrong section, I wasnt sure)
kreesj is offline
post #2 of 3 (permalink) Old 08-21-2003, 02:07 AM
If it is buy a dehumidifier <-spl? that will take care of it.
sry777 is offline
post #3 of 3 (permalink) Old 08-21-2003, 08:52 AM
Actually, 50% RH and 70 degrees F is fine. 45% RH is probably "ultimate", but you're pretty close. That's a pretty dry basement - mine gets to 70% in the summer without dehumidification.
The main thing is, if you're comfortable, your guitars should be too. So 60-80 degrees F, and 40-60% RH should be fine.
JESTER700 is offline
Similar Searches
Fret buzz / choking - temperature or humidity? stodge All Other Guitars (including Prestige) 4 07-13-2011 01:53 AM
Current temperature - awesome shreddersymphony Off-topic / Miscellaneous 16 12-24-2008 12:48 AM
temperature!! Devon8822 Tech: Setup, Repairs and Mods 3 11-23-2007 12:31 AM
Humidity/temperature kreesj Gear, Equipment, Recording & Off Topic 2 07-28-2003 05:02 PM
Temperature affect tuning? BZ Beetle Tech: Setup, Repairs and Mods 13 09-18-2002 12:24 AM
