I want to build an amp cabinet - Jemsite
post #1 of 13 (permalink) Old 05-01-2011, 11:28 PM Thread Starter
Reviews: 13
Smile I want to build an amp cabinet
I want to build an amp cabinet. I want to do this on a budget as well. I want to gear it towards my Line 6 HD500. It has MIDI output (L & R) and I can also use the standard 1/4 inch jack as well. I'm still learning this pedal, but for now, I'd like to have the option to use either MIDI or 1/4 jack for L/R.
I need to know what tools I will need (or need access to) and I'd also like to know what kind of would I should use. I'm in the market for some nice speakers (not overly expensive) and some nice wood.
I have never done this, but I want to do it so bad. To give you an idea, I'm a husband and father of 2 and they come first, so I can only do this a piece at a time.
boyd is offline
post #2 of 13 (permalink) Old 05-02-2011, 12:38 AM
Re: I want to build an amp cabinet
Most high quality amp and speaker cabs are built from Marine grade baltic birch plywood.
guitvai1 is offline
post #3 of 13 (permalink) Old 05-02-2011, 01:15 AM
Reviews: 64
A cab is just a box of wood so I don't see any kind of difficult about making one.
No matter what kind of BS companies say, the majority of cabs are made with cheap wood.
I made 2 ADA(stereo) copy cabs around 1995, I copied its dimensions from a magazine, cut its parts, glued and some screws to keep everything in place.They looked exactly like the original.
The only difficult was my parents telling me to turn the volume down all the time
Tools?
You don't know what tools you need to make a box?!
You need to cut, drill some screw holes and glue.
Plus things like a grill, feet and those things to carry it(I don't know their name in english).
6fingers is offline
post #4 of 13 (permalink) Old 05-02-2011, 01:52 AM
Reviews: 98
First--it's just a cabinet, so MIDI inputs don't apply here. Wire it for stereo with 2 1/4" jacks.
http://www.colomar.com/Shavano/construction.html
AlaskaBat is offline
post #5 of 13 (permalink) Old 05-02-2011, 09:57 AM
Reviews: 11
theres more to it then just slapping a box together guys.
Theres critical volume ratio to keep in mind as well. Some math and stuff, etc.
Denser the material wood, the better the sound, but obviously, the heavier it gets.
linuxpenguin is offline
post #6 of 13 (permalink) Old 05-02-2011, 12:07 PM
I made sealed oversized 212 cab from 15mm mediapan, and it sounds great, a lot of volume, great punch in bass, nice middle and rounded treble, no ear-punching trebles. There are two Celestion Classic lead 80's inside. The only "negative" thing about this cab is - it's pretty heavy. But the sound from it is great! I have another 212 "regular" cab with sealed back (this one I bought, didn't built it myself), but there's two vent holes in front, between speakers, and it doesn't handle louder volumes as good as my cab. In this one are two Celestion G12T-75, and they tend to break up sooner than CL80's on clean channel (I've got Laney LC30 converted to head) of the amp.
If you want cab to have volume, increase depth of the cab. I've seen 212 cab of standard height and length, but of almost a twice od depth as a standard Marshall cab, and it sounds like 412 cab.
Jibboom77 is offline
post #7 of 13 (permalink) Old 05-07-2011, 04:08 AM
Reviews: 11
agreed with most of what you said. and just to help out a bit, that word is "handle"
D.M.RG7620 is offline
post #8 of 13 (permalink) Old 06-06-2011, 10:18 AM Thread Starter
Reviews: 13
This is all awesome info. I'm saving money to start building. I can't wait.
boyd is offline
post #9 of 13 (permalink) Old 06-08-2011, 06:38 PM
i beg to differ.... guitar cabs have no need for critical volume ratio's... he is not building a tuned cab. he is building a guitar cab.
dude you need to research this on the internet. I designed a detuned 2x12 cab and built it out of flamed maple and voidless baltic birch for the baffle.
scottop1972 is offline
post #10 of 13 (permalink) Old 06-08-2011, 06:44 PM
i designed my cabs to have fairly flat response, since i was going to be using a modeller like you, i knew that the best sound these things have is direct like into a PA (lots of trial and error here). however everytime i would use my modeller direct i would get a hiss that i didnt care for. the best that it ever sounded was going into a power amp then into a guitar cab, since the 12 inch speaker in the guitar cab does not emphasize the highs or the very lows. guitars are by their nature mid range instruments. thats why they always sound best through 12's. also you dont want alot of speaker distortion. that is why i went with a speaker that had 150 watt power handling. i ended up with the eminence legend modelling 12. they no longer make these. PS your midi has nothing to do with anything you are doing.
post #11 of 13 (permalink) Old 06-08-2011, 06:47 PM
i also invested in a book called London power diy speaker cabs for musical instrument applications. by kevin o'connor. lots of theory and even some plans. great read. you should check it out.
use voidless baltic birch plywood at minimum for the baffle.
post #12 of 13 (permalink) Old 06-10-2011, 10:08 PM
Reviews: 4
Interesting. I've been wanting to hear a 15" guitar cabinet, but I don't think anyone makes them.
Thanks for linking to that book. $19 ain't bad if it helps me get what I want for cheap.
EDIT: Oops. Looks like Fender makes a Twin Custom with a 15" speaker.
Ekim is offline
post #13 of 13 (permalink) Old 06-10-2011, 11:34 PM
Vader also make cabinets which have 15" speakers.
julzius is offline
build , cab
New JS build andyt Ibanez JEM, UV, JS & Other Signature Models 82 03-28-2016 09:07 AM
New Build ringo11 Tech: Setup, Repairs and Mods 1 03-24-2010 08:19 PM
New Build help... lestrange Ibanez JEM, UV, JS & Other Signature Models 9 09-20-2009 08:47 AM
Who can build this for me? Smitty All Other Guitars (including Prestige) 0 12-15-2007 11:33 AM
cabinet? guitardevil2005 Gear, Equipment, Recording & Off Topic 4 05-13-2005 12:19 AM
