Ibanez premium tremolo - Jemsite
post #1 of 17 (permalink) Old 12-30-2017, 10:59 AM Thread Starter
I have an ibanez rg950 and I love everything about it except the trem and I am wondering if there are any other terms that I could put in that would fit. Eg edge trem, floyd or something along those lines, because I took measurements off of one of my jsí which has an edge and it looked as if it wouldnít fit so has anyone else done something like this?
Steve's Slave is offline
post #2 of 17 (permalink) Old 12-30-2017, 01:37 PM
site founder 0% owner
jemsite's Avatar
Re: Ibanez premium tremolo
see thread below that was long overdue...
http://www.jemsite.com/forums/f21/fl...ad-157993.html
good luck
jemsite is offline
post #3 of 17 (permalink) Old 12-31-2017, 05:17 AM Thread Starter
Is there any way I could change the stud space on my zero ii? Also what the difference between a zr2 and a zero ii trem?
post #4 of 17 (permalink) Old 12-31-2017, 01:21 PM
jemsite's Avatar
ZR uses the roller cam not 2-stud pivot system like your edge zero II. Anything can be changed but the amount of work would cost more than the value of the guitar and require refinishing the body. If you don't like the trem and can't come to like it really just sell the axe.
I'd be curious what you don't like about the trem & if user setup/error is a factor. I'm not in the fanclub but some ibaenz enthusiasts like these trems.
Too bad a service like reverb didn't collect & publish exit interviews for private sellers "list top-3 reasons why you are selling this guitar". It would remove a lot of speculation as to how these lesser (and incompatable with everything else) trems cause people to dump guitars such as yours. Good luck!
jemsite is offline
post #5 of 17 (permalink) Old 12-31-2017, 05:54 PM
The EZ/EZ2 and ZR/ZR2 are fully interchangeable with each other.
Rich is offline
post #6 of 17 (permalink) Old 12-31-2017, 07:59 PM
Strike that.
Any ZR will fit the EZ rout, pretty much perfectly. The EZ is a little longer than the EZ2, I'm not positive the ZR will fit the EZ2 rout. Some guitars will take an EZ and some won't. I'm not positive of the length of the ZR, but everything else about it will fit the EZ2 rout and stud spacing.
Rich is offline
post #7 of 17 (permalink) Old 01-01-2018, 03:32 PM Thread Starter
I donít like the fact I have to constantly have to tighten up the arm and how hard it is to push the bridge down. Iíve tried adjusting it at the back before you guys say that and no Iím not taking out the zero system.
post #8 of 17 (permalink) Old 01-06-2018, 07:39 AM
I fixed the arm on mine by putting a bit of electrical tape on it before inserting now it does stay nice and tight more like Edge/Low Pro Edge and Edge Pro.
Mattww is offline
post #9 of 17 (permalink) Old 01-06-2018, 08:47 AM
This is why I am afraid to get a premium over a prestige in my area some Premiums cost more than some Prestige guitars particulary the RG14XX line like the RG1450.
I hear a lot of good reviews with the Edge Zero 2. but at the same time some people who are already used to the Edge Pro say they don't like it and I have been using an Edge Pro since 2010, and considering the price I will be really sad if I ended up not liking the E.Zero 2.
I have a new RG655 and I love the feel of the trem and some say it should last longer than the Edge Zero 2, so I might stick to Edge or lo pro or Edge pro even though it may have a problematic arm bushing system. It seems the arm holder on the EZ2 is better and easier to maintain.
ShinkanPo is offline
post #10 of 17 (permalink) Old 01-06-2018, 09:02 AM
The Edge Zero 2 is very common on many models these days so it shouldn't be too hard to find a guitar with one to try it first.
I now have guitars with original Edge, Low Pro Edge, Edge Pro and now EZ2 and don't find the differences that great overall when playing. My favourite would be the Low Pro Edge as it feels the most transparent under the wrist and is what I owned first and only that for many years so is just familiar.
The Edge Pro which I had the stud mod done on just in case is very similar and even lower profile, the differences are more apparent when restringing/tuning then playing to me.
EDIT: I do prefer the arm system on the Edge/Low Pro Edge/Edge Pro because I now prefer the new carbon arms over the metal ones. The bushes aren't a problem as I normally just use the heating them up trick if they get loose so still have spares - the lighter arms don't wear them as fast anyway.
Mattww is offline
post #11 of 17 (permalink) Old 01-06-2018, 09:11 AM
The Edge Zero 2 is very common on many models these days so it shouldn't be toohard to find a guitar with one to try it first.
Thank you for the insights,
I prefer the Edge because the bridge is similar to the original floyd rose where the tail is up high and I love banging my hand on that tail!.
I do have a question how fast did the arm on the EZ2 got loose? In my Edge pro it only took like two weeks of playing and I already needed to replace the bushings.
I would assume in the case of the EZ2 since you can physically tighten it with the torque adjustment it will last much longer and can just be easily re tighten instead of buying and replacing bushings.
post #12 of 17 (permalink) Old 01-06-2018, 09:21 AM
As standard I found there was movement in the socket on the EZ2 even with the torque cap tightened.
The cap just kept the arm in a fixed position when tightened.
For dive bombs it felt OK but there was some play before pull ups and I hate any kind of wobble in the arm socket - I like even the slightest touch of the bar to have a direct effect on the bridge myself.
This is what the electrical tape solved for me, up or down now has a direct effect and there is no wobble. With the cap tightened I don't really need to touch it.
I guess if I regularly spun the arm around in circles I might but really I normally only move it a small amount just out of the way when not in use (i.e about parallel to the strings to pointing at the floor).
Mattww is offline
post #13 of 17 (permalink) Old 01-27-2018, 05:29 AM Thread Starter
How much electrical tape did you use?
post #14 of 17 (permalink) Old 01-27-2018, 06:09 AM
Not much - just one wrap around the bottom of the arm before fitting it.
Mattww is offline
post #15 of 17 (permalink) Old 01-28-2018, 06:51 AM Thread Starter
Tried that even with the thinnest amount the arm doesnít fit in the socket
edge , floyd rose , gotoh , premium rg , trem
Ibanez Premium vs Iron Label (First Ibanez guitar!) Boon All Other Guitars (including Prestige) 1 01-03-2018 12:48 PM
Premium Ibanez Jem Seafoam JEM70V with Ibanez OHSC Sevenstringer Classified Ads: Ibanez JEM/UV Guitars 2 07-24-2015 11:08 PM
NGD 2013 AT 10 Premium Andy Timmons Premium merman_93 All Other Guitars (including Prestige) 17 05-27-2013 09:32 AM
Ibanez Premium S ? erasetheprocess All Other Guitars (including Prestige) 26 01-13-2012 06:44 PM
Ibanez RG Premium FOA_Mikey All Other Guitars (including Prestige) 11 08-23-2011 01:12 PM
