Ibanez Wh10 Wah true bypass - how to install true bypass? - Jemsite
post #1 of 2 (permalink) Old 01-04-2001, 07:03 PM Thread Starter
i've got an Ibanez Wh10 wah and it really sounds great. but i wish it has a true bypass. does anyone have schematics for installing a it or an url where i can get information?
thanks for answer!
stratman is offline
post #2 of 2 (permalink) Old 01-04-2001, 07:28 PM
Go and buy a Carling DPDT switch from an electronics compay like Digikey or Mouser. I get mine over the net at www.sovtek.com , but there is a minimum buying amount of $75.00. Maybe the wah already has a DPDT, but I doubt it. Next, go to http://hail-eris.com/~stompbox/pedals/ and look for a true bypass wiring schematic. This page is my source of info in the homemade stompbox area, ANY questions you have will be answered there in one of the links. But before you jump for a soldering iron, realize that true-bypass is not always the answer. In most stompboxes, like BOSS for example, they use FET switching and the sound is buffered. You might lose some high-end with true-bypass due to cable degredation. If you have low quality cables, true-bypass wil make things WORSE. * * * * * * * *Good Luck
(Edited by UVmanMike at 6:30 pm on Jan. 5, 2001)
UVmanMike is offline
Ibanez WD7 Weeping Demon is NOT true bypass waylay00 Gear, Equipment, Recording & Off Topic 10 01-26-2018 04:29 PM
True Bypass, Do you really need it? Lussy Picker Polls 9 03-10-2010 04:35 PM
difference between true bypass and true hardwire bypass? Valhalla Gear, Equipment, Recording & Off Topic 0 10-15-2008 10:42 PM
Morley vol/wah VS Ibanez WD7. (true bypass, range, etc)... Stygian Gear, Equipment, Recording & Off Topic 8 12-17-2006 06:48 PM
ibanez WH10 true bypass stratman Tech: Setup, Repairs and Mods 0 01-04-2001 09:59 AM
