ISP Decimator II tone problem - Jemsite
post #1 of 4 (permalink) Old 06-08-2016, 10:36 AM Thread Starter
I recently picked up an isp decimator II, but I'm having a problem with it. Whenever I use it, it kills my tone and makes it sound choppy. I'm running it into a JVM205h and I have a ten band mxr eq along with a maxon od808 before the ISP. Any suggestions? I've already tried running it thru the loop.
MaidenHead is offline
post #2 of 4 (permalink) Old 06-11-2016, 10:04 PM
Re: ISP Decimator II tone problem
Isp must always go first if going in through front of amp,you are cleaning the guitar signal only NOT the effects etc...
corey j grieve is offline
post #3 of 4 (permalink) Old 06-11-2016, 10:08 PM
Also,slowly turn isp knob til hiss fades,then palm mute a single low string and pick once. You will hear the note then hiss then silence,repeat this slowly while turning isp knob until you only have note then silence.
post #4 of 4 (permalink) Old 08-27-2016, 09:19 AM
It chops and kills tone when the gate is high. You need to back it off. The JVM is a beast. You need to balance out the gain on the amp with everything else.
renips is offline
FS: ISP NOISE DECIMATOR! Schwarzwind Classified Ads: Guitars and Gear 0 09-07-2011 10:21 PM
[CAN] FS/FT: ISP DECIMATOR! Levi79 Classified Ads: Guitars and Gear 2 01-21-2011 02:13 AM
FS: ISP Decimator ProRackG malin Classified Ads: Guitars and Gear 0 01-18-2011 10:00 AM
FS: ISP Decimator Speedy Fingers Classified Ads: Guitars and Gear 1 09-17-2008 01:58 PM
ISP Decimator chaos731 Gear, Equipment, Recording & Off Topic 12 06-26-2008 01:46 PM
