JCM 800 sound clips - Jemsite
post #1 of 26 (permalink) Old 07-19-2003, 04:44 PM Thread Starter
JCM 800 sound clips
Anyone got any? I want a sound clip of an unmodified JCM 800 (if possible) with maybe a booster pedal? Just post what you got, I'm thinking about buying one!
Jeff is offline
post #2 of 26 (permalink) Old 07-19-2003, 05:18 PM
If you're looking for a booster pedal, I know the Boss OD-10 (the twin pedal distortion thingy) has a "boost" setting that gives you a pure volume boost, as well as models of the Ibanez Tube Screamer, among other pedals, and Boss pedals including the DS-1, etc. It sounds great too.
Two hands31 is offline
post #3 of 26 (permalink) Old 07-19-2003, 06:10 PM Thread Starter
I think you read my post wrong, or I probably wrote it wrong lol! I want to hear a sound clip the JCM 800 with a booster pedal.
Jeff is offline
post #4 of 26 (permalink) Old 07-19-2003, 07:28 PM
Yeah, I'd really be interested in that one too. I'm using it currently as the main amp in my pod (don't ask me why *lol*)... I always wondered what they sound like for real. I was thinking of maybe buying one in the future, as they seem to go more or less cheap on bay
Fabe
Fabe is offline
post #5 of 26 (permalink) Old 07-19-2003, 11:26 PM
All I have is a quick DI clip of my JCM 900 SL-X w/ EL-34's. Let me know if you want to hear it.
jeff l is offline
post #6 of 26 (permalink) Old 07-20-2003, 01:40 AM Thread Starter
I can host it if you need me to.
Jeff is offline
post #7 of 26 (permalink) Old 07-20-2003, 03:10 AM
JEMavenger, here's the SL-X clip. I wish I had more of the Marshall recorded but I was just fooling around with the 'recording compensated output' to hear how it would sound straight into my soundcard. It's just one lick.
It usually takes a couple of tries to hear the whole thing.....my player chops the end off on the first pass every time.
http://www.digitalsoundplanet.com/Me..._000008946.mp3
jeff l is offline
post #8 of 26 (permalink) Old 07-21-2003, 01:37 PM
I've got an '82 JCM 800 4010 (1x12 50watt). It's identical in every way to a 2204 50 watt head. When I get home from work, I'll record a quick couple of clips for you and upload 'em ASAP (hope Macintosh format is okay).
The "booster" pedal I use is a late-model Taiwanese BOSS OD-1 Super Overdrive, nothin' fancy.
JEMavenger: Do you want to hear it through a Marshall 4x12 Vintage-30 cab, or the original Celestion 65 that's in the 1x12 combo?
--jr
JohnnyRasgueado is offline
post #9 of 26 (permalink) Old 07-21-2003, 02:13 PM Thread Starter
--jr
I'd rather hear it through the cab, because that's what I am planning on purchasing. And what do you mean 'macintosh format'? Could you please record it in mp3, or maybe even a small wav, or tell me of a player where I can play the clip? Thanks for everything dude.
Jeff is offline
post #10 of 26 (permalink) Old 07-22-2003, 12:42 PM
I could record a clip of my TSL's crunch channel through a mesa recto 2x12, which is supposed to be fairly jcm800 in persuasion... never played the real thing, though, so i couldn't tell you.
-D
Drew is offline
post #11 of 26 (permalink) Old 07-22-2003, 03:33 PM
Okay, here we go.
Here are four quick MP3s of my '88 777DY running into a BOSS Super Overdrive SD-1 (Sorry ... I accidentally wrote "OD-1" the first time). These were recorded with a super-cheap Radio Shack mic from '89 straight into my Korg D-16, no effects, no EQ.
Amp settings:
Preamp dimed. Master on 2. Treble at 9. Middle at 5. Bass at 10. Presence at 8.
BOSS settings:
Level at 2:00. Drive at 10:00. Tone at high noon.
777DY settings:
Both volume and tone dimed.
Sustaining Chords
Some sustaining 6-string chords. Trying to show the clarity of all six strings and demonstrate compression/sustain characteristics of the JCM 800. Bridge 'bucker.
Bends and legato
Cheesy little blues pentatonic run. Lotsa bends and harmonics. Bridge 'bucker.
Neck 'bucker run
Quickie little run with the neck position. Attempting to demonstrate articulation and attack.
Bridge 'bucker run
Ditto, only with the bridge 'bucker.
Hope these help you out. Personally, I love the 800s ... that 2203 reissue with the built-in effects loop is darn temptin'!
--jr
post #12 of 26 (permalink) Old 07-22-2003, 05:11 PM
You can check out pretty much anything done by Zakk Wylde. That is all he uses plus EMG pups.
DLHelfand is offline
post #13 of 26 (permalink) Old 07-23-2003, 07:25 AM
Not to turn this into a "ghostbuilder" thread, but I've heard tell that Zakk's amps are actually M&Gs inside of Marshall housings. Take that for what it's worth.
--jr
post #14 of 26 (permalink) Old 07-24-2003, 10:27 PM
M&G's??? WTF is that. Dont go by those shrill clips either. The jcm 800 dont sound anything like that bad recording.
motogod927 is offline
post #15 of 26 (permalink) Old 07-25-2003, 01:22 PM Thread Starter
I kind of liked the sound of them.
Jeff is offline
amp settings , boss pedal , boss pedals , ibanez tube screamer , mesa recto , neck position , speaker cab , spring reverb , super overdrive , zakk wylde
Mo' joe sound clips? daniel ibanez js100 Pickups & wiring 0 01-22-2010 07:34 PM
Sound Clips RGR570 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 12 09-29-2007 01:56 AM
Sound Clips Thrash Ibanez JEM, UV, JS & Other Signature Models 1 12-07-2004 05:29 AM
More ADA MP-1 sound clips RobV Gear, Equipment, Recording & Off Topic 3 02-20-2004 09:46 AM
VHT sound clips Al M Gear, Equipment, Recording & Off Topic 0 08-15-2003 09:05 AM
