jemini pedal help - Jemsite
post #1 of 14 (permalink) Old 08-31-2012, 10:41 PM Thread Starter
Exclamation jemini pedal help
Hey i bought a jemini pedal a few days ago and when i use it it seems to act like more of a fuzz pedal, and not in a good way. on the clean channel its unusable and added to the dirty channel its not bad but there is still an unpleasant fuzzy ripping like quality to the tone. im playing it through the front of a new mesaboogie trans atlantic 100watt head with a jem7vwh. any suggestions? thanks
j.page is offline
post #2 of 14 (permalink) Old 09-01-2012, 01:05 AM
Re: jemini pedal help
Distostion pedals do this if they dont have enough power going to them. If your using a power supply try running just the jem pedal into the am alone. If it still is fuzzing try using a battery. Maybe your power supply does not have enough m/amps to runn all your pedals ?
Let us know how you go.
paul72 is offline
post #3 of 14 (permalink) Old 09-01-2012, 02:24 AM
Reviews: 98
Which side of the pedal does it, green or red?
Try backing the tone knob off to 12 o'clock and see if that helps. The tone control on most distortion and ODs sound like bees in a can if all the way up.
AlaskaBat is offline
post #4 of 14 (permalink) Old 09-01-2012, 07:16 AM Thread Starter
It does it on both but more on the red. i have the tone at 12 already
j.page is offline
post #5 of 14 (permalink) Old 09-01-2012, 07:31 PM Thread Starter
Also i have a duracel 9v battery inside..wouldnt thT be completely sufficient? its brand new
j.page is offline
post #6 of 14 (permalink) Old 09-01-2012, 09:17 PM
Reviews: 98
Put a multimeter on it to make sure that battery is supplying correct voltage.
Could you post some clips so we can hear it?
post #7 of 14 (permalink) Old 09-01-2012, 11:32 PM
+1
And if you can't get out of that pedal a decent tone, sell it and get a real pedal. I mean, that's the classic pedal that guitar players try to sell but they never use... ask why.
Tungisul is offline
post #8 of 14 (permalink) Old 09-02-2012, 03:34 AM
Reviews: 98
The Jemini is not a bad pedal. In fact, it's better than average. There are better ones out there, but the Jemini sounds great in either mode.
Remember, a pedal alone will not give you a great sound. It's just one piece of the tone puzzle.
post #9 of 14 (permalink) Old 09-02-2012, 05:42 AM
I was not happy with mine, even though I ran it trough a legacy with a jem on the input. Too thin and fizzy. Also, enabeling the circular leds which made the pedal consume about the double and introduced a hiss! I'd dail the knobs back and add carefully. Check the youtube demo of vai.
Silverburst is offline
post #10 of 14 (permalink) Old 09-02-2012, 09:05 AM
I have had a jemini for about 3 years now, and I really really like mine.
What I would suggest is:
The bright switch, use it, since it DOES alter the tonality of the pedal, because it directs more/less energy to the LEDs. Maybe changing that helps.
And get yourself a power supply cable. That usually helps as well.
Ibanezrg is offline
post #11 of 14 (permalink) Old 09-02-2012, 06:20 PM Thread Starter
My patch cables are getting pretty much near garbage, could that also be the reason for the ripping bas fuzz and aweful bottoming out?
j.page is offline
post #12 of 14 (permalink) Old 09-02-2012, 06:30 PM Thread Starter
j.page is offline
post #13 of 14 (permalink) Old 09-02-2012, 06:33 PM
Reviews: 98
Yep--that's a big factor.
post #14 of 14 (permalink) Old 09-02-2012, 07:20 PM
The Jemini does sound hairy, or fuzzy if you want - on purpose. I suspect that it's just the way Mr. Vai likes it, and it's a case of what works for him doesn't necessarily work for everyone...
ieronim is offline
distortion , jem , jemini , steve , vai
Jemini pedal wanted jsdisciple Classified Ads: Guitars and Gear 4 05-17-2011 06:08 PM
New feature for the Jemini pedal? Angra1 Gear, Equipment, Recording & Off Topic 10 02-03-2011 09:04 PM
JEMINI Pedal????? ibanezking Gear, Equipment, Recording & Off Topic 12 11-19-2010 04:16 AM
Jemini Pedal Turcotte Gear, Equipment, Recording & Off Topic 163 12-19-2009 09:42 AM
FS: Ibanez Jemini Pedal zar7 Classified Ads: Guitars and Gear 3 10-02-2008 11:22 AM
