JSX Head Ultra and Crunch Channels don't work - Jemsite
post #1 of 7 (permalink) Old 09-29-2009, 08:17 PM Thread Starter
I have a JSX head and the Ultra and Crunch channels stopped working. The Clean still sounds fine. Can anyone tell me if I can fix this with new tubes without taking it into a shop?
Thanks
Shibumi is offline
post #2 of 7 (permalink) Old 09-29-2009, 08:31 PM
jb4674's Avatar
Reviews: 18
Re: JSX Head Ultra and Crunch Channels don't work
Just replace the tubes with the same type of tubes and you should be good to go. Take each tube out (one at a time) and examine it. If it doesn't look blown, then place it back. If all the tubes are ok, then it might be the preamp tubes. If you're not comfortable doing this, call a shop and find out how much they charge for diagnostics.
Jimmy
jb4674 is offline
post #3 of 7 (permalink) Old 09-29-2009, 08:32 PM Thread Starter
Thanks Jimmy.
Shibumi is offline
post #4 of 7 (permalink) Old 09-29-2009, 08:35 PM
jb4674's Avatar
Reviews: 18
I forgot to mention that you should make sure the amp is unplugged (unplug the power cord from the amp itself and the wall) for a good amount of time (give it an hour just to be in the safe side), just in case.
Jimmy
jb4674 is offline
post #5 of 7 (permalink) Old 09-29-2009, 08:37 PM
And wear plastic gloves or something, because you don't want hand grease all over your precious hot glass tubes.
Magical Muffin is offline
post #6 of 7 (permalink) Old 09-29-2009, 10:55 PM
sounds like preamp tubes to me.. look in the manual and determine which are used by both channels.. swap until you fix the problem!
shogun is offline
post #7 of 7 (permalink) Old 09-30-2009, 07:25 PM Thread Starter
Thanks everyone...Got it all together including the beverage!
Shibumi is offline
crunch , head , jsx , problem , ultra
humming noise from JSX head gain channels just42dave Gear, Equipment, Recording & Off Topic 6 07-24-2008 04:15 PM
WTB: Peavey Ultra Plus head. Leary Classified Ads: Guitars and Gear 0 07-07-2007 03:52 PM
Fs/FT: Vht Ultra Lead Pittbull Head! LennyX Classified Ads: Guitars and Gear 3 01-10-2006 06:22 PM
WTB: Peavey Ultra Plus 100 Watt Head Jackson Soloist Classified Ads: Guitars and Gear 0 09-26-2005 05:17 PM
WTB: Peavey Ultra Plus Head Leary Classified Ads: Guitars and Gear 3 08-24-2005 07:50 PM
