Korg AX300G be used as a switching system? - Jemsite
post #1 of 5 (permalink) Old 07-11-2012, 06:45 AM Thread Starter
Would anyone happen to know if the Korg AX300G can be used with a valve amplifier, basically like a switching system as id like to used the fx from the Korg AX300G with the clean/crunch/lead channels of my amp, also if this is possible how would it be done?
Many thanks
Dannymanc81 is offline
post #2 of 5 (permalink) Old 07-11-2012, 08:13 AM
Reviews: 120
Re: Korg AX300G be used as a switching system?
Best bet would be to check the manual.
If you don't have one on hand I bet there's one online. Just do a Google search. If it can do what you want it'll be in the manual.
LonePhantom is offline
post #3 of 5 (permalink) Old 10-30-2012, 07:32 AM
You'll need to use the midi on the AX3000g to switch the amp channel through one of these.
http://woboge.com/midi.html
Marine Boy is offline
post #4 of 5 (permalink) Old 11-01-2012, 01:46 PM
Reviews: 9
Hey Marine Boy!! I'm in agreement with Marine Boy, it needs to be midi compatible! If you have 2 channels you'll need something like the Wobo midi switcher or if you have more than 2 channels something from GLabs or Voodoo labs that has some other midi connections. You'll need to do some research on how your amp is switched whether it's a quarter inch jack or a proprietary midi type jack or a standard midi type jack.
longi is offline
post #5 of 5 (permalink) Old 11-01-2012, 02:07 PM
Ayup mate. I hang out here too as my number 1 gun is an Ibanez RG1550 Prestige (with all mod-cons). I mailed Wobo on Monday re the 8 pin DIN midi switcher from my amp but am yet to hear anything.
korg ax300g
Switching my tremolo system Yelgath Tech: Setup, Repairs and Mods 6 11-21-2008 11:54 PM
S-1 Switching System newbieguitarmaker All Other Guitars (including Prestige) 7 08-10-2008 09:03 PM
Pickup switching system on my RG2550 bsrg2550 All Other Guitars (including Prestige) 2 06-01-2008 02:53 AM
Split5 Switching system on my JEM10th JEM10th Pickups & wiring 4 11-17-2004 04:41 AM
my korg ax300g is giving me headaches 403 Gear, Equipment, Recording & Off Topic 0 09-06-2003 03:43 PM
