legacy 50 watt setting - Jemsite
post #1 of 5 (permalink) Old 07-18-2005, 09:51 PM Thread Starter
Question legacy 50 watt setting
just curious,..on the 50 watt setting are all the tubes suppose to be lit up?? mine are....and i thought it was suppose to be only two. (or is it just 2 that are actually working but they all light up)
also any advice on a way to work the tubes without the volume being so loud?
wideopen98 is offline
post #2 of 5 (permalink) Old 07-19-2005, 11:13 AM
rgr
Re: legacy 50 watt setting
Yes, all the heaters will still be on. I'm not sure if the Legacy runs all 4 tubes in Triode mode vs Pentode mode or if it just cuts out 2 of the tubes, but either way, everything is fine.
Roger
rgr is offline
post #3 of 5 (permalink) Old 07-19-2005, 11:41 AM
it cuts out 2 tubes,. but all heaters are on.
EL-CeeDee is offline
post #4 of 5 (permalink) Old 07-21-2005, 05:49 PM
Whoa guys...
Pentode mode uses all 4 filaments of the tube. Triode uses only 3 which cuts the wattage down (in half, ironically!). All 4 tubes are still used in both modes.
What was cool about the 30th anniversary Marshall is it had a triode/pentode switch AND a switch to go from 2 to 4 power tubes, in effect giving us 50 or 100 watts with 4 power tubes, or 25 or 50 with only 2. That option is pretty rare though.
red5 is offline
post #5 of 5 (permalink) Old 07-21-2005, 07:29 PM
i know it's kinda off topic, but the switch for selecting 50/100 watts fell off inside of my legacy. does anyone know what to do because i don't really want to send it in for a repair that small.
knarfzednem is offline
carvin legacy 100 watt head sarzie Classified Ads: Guitars and Gear 0 11-14-2011 01:21 PM
Carvin Legacy 100 watt tube head amplifier - $475 plus shipping mfergel Classified Ads: Guitars and Gear 2 03-25-2010 08:10 PM
Carvin Legacy 100 watt head primerib Classified Ads: Guitars and Gear 0 12-05-2009 09:49 PM
Line 6 Vetta II 300 Watt Modeling Guitar HD VS Hughes&Kettner Switchblade 100 watt HD OLIE_ROCKS_THE_80'S Gear, Equipment, Recording & Off Topic 14 12-25-2007 05:04 AM
Legacy - 50/100 watt switch RSVampire Gear, Equipment, Recording & Off Topic 12 10-14-2007 07:06 PM
