Legacy effect loop - possible ground loop hum? - Jemsite
post #1 of 5 (permalink) Old 08-12-2001, 12:50 PM Thread Starter
I've had a legacy half stack for about a year and have enjoyed it. *During that time I've been running an
Intellifex in the loop and it has operated quietly. *Usually, I would just set the Intellifex on top of the head.
Now, I just got a GCX audio switcher so I can switch between my Triaxis / 2:90 setup and my Legacy setup
without messing with cables. *I want to use the Intellifex for both rigs so I've moved it into the rack. *With
the Mesa loops the Intellifex is perfectly quiet... but the legacy loop now has this very loud hum. *Is this
a ground loop situation? *Everything is powered from the same outlet via a Furman strip. *If I move the Intellifex
back to the top of the head it is quiet again.
BTW, I've put the Intellifex in the rack and cabled the Legacy loop directly to it (to eliminate the GCX switcher
from the picture) and I still get the loud hum.
Any ideas on what I should try to fix this?
thanks
bill h is offline
post #2 of 5 (permalink) Old 08-12-2001, 02:05 PM
Legacy effect loop
Hey Bill.
Is yer Intellifex using one of those goofy wall-wart power adapters like my Hush IICX is? If so that's your problem. You need to ground that power supply somehow before you plug it into your Furman.
My Hush hums like crazy, kinda ironic innit?
jeffrey is offline
post #3 of 5 (permalink) Old 08-12-2001, 02:37 PM Thread Starter
Legacy effect loop
Hey Jeffrey,
Yep, it's using one of the wallwarts. *So, if it is causing the hum, wouldn't I hear it when running between
the Triaxis and the 2:90? *Also, even when I set the intellifex on top of the legacy head I still usually have
it plugged into the furman in my rack so I can power everything up with one switch (and I don't get the hum).
bill h is offline
post #4 of 5 (permalink) Old 08-12-2001, 02:46 PM
Legacy effect loop
I dunno.
It's kinda strange I admit. Check out my scenario.
If I run through the hush direct (guitar > hush > amp), not that I'd ever use it that way I did it just for testing.
If I run it like that , it doesn't hum. Put it in the loop, it hums like crazy.
Hrm. Know what I just thought of? Those wall warts put out RFI. I wonder if that wall wart being up in my rack is the problem being it's so close to my effects units.
I need to try plugging it into the wall or something.
It's the same thing with some ppl using AC adapters on pedals. Makes'em hum like crazy, use a battery, no hum.
I'm gonna try and plug that thing into the wall just for the hell of it, see if I lose the hum.
jeffrey is offline
post #5 of 5 (permalink) Old 08-12-2001, 03:05 PM
Legacy effect loop
Well ****.
I think my Furman PL-8 is dead. I unplugged everything and plugged it into a little APC powerstrip and it's all fine, hum-free.
Argh.
jeffrey is offline
ground loop prevention qwesion 2DECADESSOFAR Pickups & wiring 0 11-18-2012 09:20 AM
Ground Loop? LethalAe86TypeR Gear, Equipment, Recording & Off Topic 6 08-29-2007 08:42 PM
Using an amps effect loop? ZOMB13 Gear, Equipment, Recording & Off Topic 4 12-21-2005 11:17 AM
2027 ground loop - a possible solution Scott of Actual Time All Other Guitars (including Prestige) 0 11-05-2001 09:49 PM
Eventide H3000 and Legacy effect loop? stevevai Gear, Equipment, Recording & Off Topic 15 12-22-2000 02:52 PM
