Line 6 POD - it pops when i change the channel? Help! - Jemsite
post #1 of 5 (permalink) Old 01-19-2003, 11:56 AM Thread Starter
hi:
I have a pod 2.0 trough a mes power amp and marshall cab for some testing. I have noticed that when i change channels with the fb4 there is a small pop and it is really ugly if you have to change between a clean an crunch setting.
I want to buy a flextone II combo, does it happen the same?
thanks
fernando
theblackpage is offline
post #2 of 5 (permalink) Old 01-19-2003, 12:52 PM
The Flextone II doesn't, and the POD 2.0 shouldn't either, depending on what version of the software you have I think.
Two hands31 is offline
post #3 of 5 (permalink) Old 01-20-2003, 01:07 PM Thread Starter
what i by "pop" is a small delay when i cange settings, is this normal? does it happen with the flextones?
thanks again
post #4 of 5 (permalink) Old 01-20-2003, 02:44 PM
thanks again
Yes, it's normal for early versions, and I think the early Flextone IIs do it too, however, getting the updated software fixes it. It's a free download off the site, or if you buy a new Flextone II or POD, you'll get the new software standard.
post #5 of 5 (permalink) Old 01-21-2003, 10:04 AM
i thought you were have the same pop problem that i have with my marshall vs100r
the damn thing makes a big POP craking sound when i switch between my clean and distortion channels. I don't know what it is but i does stop 5 or so minutes into the amp being on????
Dave Goodland is offline
power amp
locking nut pops every time I use trem evolvedmb Tech: Setup, Repairs and Mods 4 01-31-2012 09:14 AM
Single channel ram versus Dual channel ram results. Rotti Off-topic / Miscellaneous 3 01-03-2008 01:18 PM
pops and crackles... (this is getting tedious now...) Kev Brigden Gear, Equipment, Recording & Off Topic 7 02-06-2004 05:37 PM
My Legacy crackles - Actually, it snaps and pops, too bduersch Tech: Setup, Repairs and Mods 10 03-02-2001 12:59 AM
My Fender Princeton Chorus pops - amp problem jem7vwh Tech: Setup, Repairs and Mods 0 03-01-2001 02:54 PM
