Low wattage power amp to drive an external preamp - Jemsite
post #1 of 4 (permalink) Old 08-13-2010, 08:36 AM Thread Starter
Hi guys,
Is there a good low wattage power amp to drive an external preamp (not a modelling amp, so no power amp modelling in there) ? For home usage while preserving tone and not getting overly loud!
From what I've seen most power amps are minimum 20/20 watts which is probably still to much to use at home!
Or maybe I'm missing some special one ?
Maybe a solid state power amp ? But even then the minimum is like 100w... I'm thinking Rocktron velocity 100.
Alternatively a low watt amp could work as long as it has an effects loop and is known for "digesting" pedals well ? Something like the Blackstar HT-5 ?
mindwalker is offline
post #2 of 4 (permalink) Old 08-13-2010, 07:15 PM
Reviews: 120
Re: Low wattage power amp to drive an external preamp
Go the HT-5, they are awesome amps.
LonePhantom is offline
post #3 of 4 (permalink) Old 08-13-2010, 08:21 PM
Reviews: 130
The best ones out there I've encountered are the Mesa 20/20 and the Marshall EL84 20/20. I own the Marshall and can honestly say everything I run through that sounds at least 50% better, and you can run it at bedroom volumes easily enough. Otherwise, I'd say get a good sounding power amp (any wattage) and use an attenuator such as a ROCKMAN Power Soak, Marshall Power Brake, THD Hot Plate, etc.
Cheers,
Race
racerevlon is offline
post #4 of 4 (permalink) Old 08-16-2010, 05:47 AM Thread Starter
Thanks for the heads up guys! I will try both the HT-5 and the poweramp options!
poweramp , preamp
FS: VHT 2/50/2 power amp and VHT GP3 preamp ALL TUBE sfx70 Classified Ads: Guitars and Gear 2 09-17-2010 08:11 PM
Preamp, power amp... HELP Metal Tiger Gear, Equipment, Recording & Off Topic 13 06-04-2007 10:19 AM
FS: Glyph GT050 250 GB external hard drive Koss Classified Ads: Guitars and Gear 0 12-02-2006 07:41 AM
Low power/low wattage tube amps slugman Gear, Equipment, Recording & Off Topic 27 09-17-2006 01:17 PM
Power amp wattage.. - will I blow my speakers? dwswift Gear, Equipment, Recording & Off Topic 13 01-27-2001 12:14 AM
