Marshall 1936 2x12 problem - Jemsite
post #1 of 6 (permalink) Old 05-22-2011, 06:08 PM Thread Starter
Reviews: 3
Ok, so i recently scored a used 1936 cab for $300 Canadian. I get my bugera 6260 head delivered(btw, its going back, i dont like it), plug it in, match the impedance. Plug the cable into the 8 ohm mono jack on the cab. Play, put my ear to the speakers(dont worry, it was low volume) and sound is only coming through the left side. If i plug the cable into the 16 ohm right jack, it comes through the right speaker only. So right now, the cab only works as a stereo cab, but i want to be able to use it as a mono cab, woth both speakers going at the same time. Any thoughts on this, and how to fix it?
IBZshredder is offline
post #2 of 6 (permalink) Old 05-22-2011, 06:14 PM
Re: Marshall 1936 2x12 problem
so it has two 16 ohm speakers? I don't know why mono mode doesn't work as expected, it could be that someone rewired it? When you use 8ohm jack do you have something plugged in the other jack (you shouldn't)?
If you don't need stereo mode, just unsolder both jacks and wire speakers in parallel (black with black, red with red or whatever the color is) to one of the jacks and leave the other open. That will give you 8ohm total impedance. Otherwise, you can try to restore it to the original state. One of the jacks should be switching mode to make that happen.
Cheers
bancika is offline
post #3 of 6 (permalink) Old 05-22-2011, 06:19 PM Thread Starter
Reviews: 3
well it is supposed to be able to have a non switchable mono and stereo. if i have two speaker cables going to it, it runs at 16 ohms. And id like the flexibility of being able to go from mono to stereo. But if nothing works, i'll do what you said.
post #4 of 6 (permalink) Old 05-22-2011, 06:34 PM
what I meant by "switchable" is jack construction for the 16ohm right jack. When you plug something in it cuts the other speaker out of the mix, so that you can use it with the other jack. When nothing is plugged in the right jack, it switches the right speaker in parallel with the left one. Check if the wiring is good.
bancika is offline
post #5 of 6 (permalink) Old 05-22-2011, 06:52 PM Thread Starter
Reviews: 3
i'll try to get pics. I should be able to run the cab in mono 8 ohms by plugging a cable into the left jack, which would activate both speakers. But it's not doing that.
post #6 of 6 (permalink) Old 05-22-2011, 08:28 PM Thread Starter
Reviews: 3
I think this problem might have just been in my head. I turned the head up half way, put my leg in front of both speakers pone at a time, and could feel my leg hair moving for both
2x12 , celestion , marshall
WTB: Marshall 1936 and ADA MC-1 cerealk Classified Ads: Guitars and Gear 0 10-15-2010 09:24 PM
FS/FT - Marshall 1936 2x12 Cab - UK Seller Bono Classified Ads: Guitars and Gear 0 11-02-2005 12:33 PM
FS: Laney VH100R + Marshall 1936 2X12 Adagio_777 Classified Ads: Guitars and Gear 3 06-23-2005 06:51 AM
Peavey JSX and Marshall 1936 2x12 Benson Gear, Equipment, Recording & Off Topic 4 10-24-2004 03:26 AM
Marshall 1936 vs. Carvin Legacy 2x12? Drew Gear, Equipment, Recording & Off Topic 12 03-06-2003 02:14 PM
