Marshall amp settings - Jemsite
post #1 of 7 (permalink) Old 08-11-2005, 05:41 PM Thread Starter
Hi
I have a Marshall TSL60 combo, as I'm sure some of you other guys do, and I was wondering what settings you had it on to acheive a metal-esque lead or rhythm tone? I'm struggling to make mine sound anything other than bluesey or like a sludge of gain.
thanks.
corganrocks is offline
post #2 of 7 (permalink) Old 08-11-2005, 09:21 PM
Re: Marshall amp settings
This is why I don't like JCM 2000s. They have a decent mild gain and clean tones and fizzy high gain tones.
These amps sound best with the master volume around 4 or 5 as opposed to the Marshalls of the past which weren't that impressive with the MV around 4 or 5, but sounds better the higher the MV gets.
You have the Deep setting and the mid scoop setting, leave both off. Try the clean channel with the gain at 10. If you need more gain try the cleaner of the lead channels, but the best sounds on these amps comes from the clean channel. As for EQ, put all the controls at 12 oclock and adjust them from there - that's what I always do and suggest to everyone.
red5 is offline
post #3 of 7 (permalink) Old 08-12-2005, 09:27 AM
Contributor
jemaholic's Avatar
The owners maual should offer settings for different sounds.
jemaholic is offline
post #4 of 7 (permalink) Old 08-12-2005, 03:30 PM
^^ Some owners manuals do, some do not. I am not sure if Marshall started doing that with the JCM 2000 line or not.
The problem with those presets is that they do not know what kind of guitar you are running through the amp. Different guitars, woods, pickups will have different tonal qualities, especially single coils and humbuckers.
That is why I say start with the EQs around 12 oclock and adjust as necessary from there!
red5 is offline
post #5 of 7 (permalink) Old 08-16-2005, 10:15 PM
I've got a TSL100...tweaking the knobs is about my favorite pastime..I mostly play Satriani (attempt, that is)...I'm usually playing a JS100...don't know if this is "heavy" enough for you
don't know if your amp has a crunch channel, but this works best for me, although I've used the clean channel a lot as well...I have the bass at max, mid @ 4 & treble @ 4...I experiment with the treble a little higher, say 6 to 7, but I always go back to 4...volume/gain @ 2, which is plenty loud enough for my house...deep switch is in, tone switch out...presence @ max & reverb about 8 (most articles say Satch doesn't use reverb, which is fine with me, but I like how it sounds in my house)...I'm telling you, you don't need a lot of gain, but then again, I do run a Boss DS-1 with tone @ 9 o'clock, level & distortion @ 3 o'clock (most articles say Satch has the distortion setting full tilt - maybe he needs to on the JSX or for higher volumes, but most of his tone isn't all that distorted if you think about it - he must not be using any gain to speak of, but I don't know)...I also run a Digitech Whammy, always turned on, with a 1-octave up setting & the pedal "off" or fully down (except when I actually use it on such tunes as Raspberry Jam, then I work the pedal)...the Whammy being on gives the sound a bit more of a mellow quality to me...mellow distortion?...I'm running a delay through the FX loop & chorus is available too, but I don't use chorus much...sorry to ramble on about Satch stuff...haven't found the lead channel to be of much use - yet!
I like old Black Sabbath...here again, I'll simply adjust the DS-1 a little...basically, I just set the tone to about 11 o'clock as some of their older tunes are more trebly to me & maybe I push the distortion up all the way, maybe not...I tweak the delay to get more of doubling sound (this setting is in the Boss delay manual)...I switch to an SG guitar...I basically don't have to touch the amp - the crunch channel shines again to my brain
The Boss DS-1 just gives you a lot more flexibility to me...I also like Rush & the Allman Brothers - tweaking the DS-1 to taste just about covers it all...you need to try one & they aren't that expensive - mine was under $40...sounds like I'm a saleman for Boss, but I ain't
I use a flanger & wah as well as required..will be trying a Fulltone DejaVibe next...anybody got one?
I've also got a 12-year old Marshall 8040 that still works fine, but the tone doesn't compare to the TSL100 & it isn't supposed to anyway...all in all, the day I got the DS-1, as far as basic effects go, was my best purchase
keywe is offline
post #6 of 7 (permalink) Old 08-22-2005, 11:38 PM Thread Starter
thanks for our replies gentlemen. I think the REAL answer is simply to sell the marshall and get native instruments guitar rig. have you guys ever played this thing? it's AWESOME! like the ultimate high quality multi effects box. not very rock n roll to be playing through a laptop but i guess i can always hide it in a rack case and loop it straight into the PA. I hear NiN and Garbage do something similar. it's the way of the future gentleman. x.
post #7 of 7 (permalink) Old 08-23-2005, 02:27 PM
I would keep a 2x12+ sized combo around though. You might like a recto or something, I am guessing...
red5 is offline
clean tone , digitech whammy , high gain tones , marshall tsl
FS: Boogie Triaxis, Marshall JMP-1 Preamp, Marshall Stereo Power Amp 20/20 TheTrooper Classified Ads: Guitars and Gear 3 10-22-2013 12:47 PM
1971 Marshall 1960B & 1982 Marshall Anniversary 1960A white Sevenstringer Classified Ads: Guitars and Gear 6 01-27-2013 05:05 PM
JSX Clean Channel settings - Joe's settings? Toadfish Gear, Equipment, Recording & Off Topic 6 02-11-2009 04:25 AM
Settings for good tone from Gibson SG and Marshall TSL601!!! Kroeger Gear, Equipment, Recording & Off Topic 5 08-11-2004 03:31 PM
Marshall JCM800, settings and effects? saTa Gear, Equipment, Recording & Off Topic 6 12-19-2003 10:22 AM
