Mesa Boogie 20/20 Power Amp - How Loud? - Jemsite
post #1 of 5 (permalink) Old 09-02-2003, 01:08 PM Thread Starter
How big a venue could I fill if I was running a POD Pro and a Mesa Boogie 20/20 Power amp? My local venue is about 10 metres x 10 metres. Is this loud enough?
Thanks
Joe
SuperJemBoy is offline
post #2 of 5 (permalink) Old 09-02-2003, 01:52 PM
I don't think you'll have much of a problem being heard.
Most times even with my main rig, I'm being mic'ed out into a P.A.
Bamm
bammbamm is offline
post #3 of 5 (permalink) Old 09-02-2003, 05:28 PM
In a 70' X 70' (say 23m X 23m) room with a couple hundred people in it, my 20/20 keeps up fine pushing a pair of 1x12" Mesa cabs. In a room that's 30 feet a side, you'll be plenty loud. Outdoors, or in really big halls, you'll have to run an XLR line out from the 20/20 to the PA, but that's no biggie either so long as they have the hole on the board...
Jimi D is offline
post #4 of 5 (permalink) Old 09-03-2003, 03:07 AM
Like Bamm said, I would expect you'd be mic'd to a PA to get a good mix. The 20/20 should do fine.
bpd111 is offline
post #5 of 5 (permalink) Old 09-03-2003, 01:00 PM
i run a Mesa 20/20 with a peavey rock master tube preamp in a 1x12 rack combo i built. i run the +3 dB output of the preamp into the power amp to overdrive the input a bit, and it's all dirty tones, no clean. i could not turn the power amp above 1 o'clock at an outdoor field gig for fear of completely blasting away the rest of the band. and i really wanted to, it was a big field!
it won't do crystal clean at those volumes, the power tubes will get gritty, but it will easily fill a room. like any good tube amp, the closer you run it to its limit, the better it sounds.
mesa boogie , mesa cab , mesa cabs , pod pro , power amp , tube amp , tube preamp
WTB: MESA BOOGIE 20/20 Power Amp or 2:50 Power Amp guitarjake Classified Ads: Guitars and Gear 0 07-23-2011 12:05 AM
Mesa Boogie 3 channel Triple Rectifier head and Mesa Boogie 2:90 Power Amp Sevenstringer Classified Ads: Guitars and Gear 3 12-03-2010 09:40 AM
mesa boogie power amp Vince~ Gear, Equipment, Recording & Off Topic 3 06-09-2006 01:46 AM
WTB: Mesa/Boogie 20/20 power amp nexus66ix Classified Ads: Guitars and Gear 0 02-15-2005 03:01 AM
