Mesa Boogie Quad Problem PLease Help - Jemsite
post #1 of 5 (permalink) Old 03-10-2004, 10:07 PM Thread Starter
On my Quad, Channel 2 seams to be alot quieter than channel 1. Its
to the point where I cant have channel one be a distroted lead sound
becuase when i turn on channel 2 I wont be able to hear it.
Any suggestions? the tubes are fine. The power amp is fine.
My channel B outpet Level knob does NOT work, does anyone know how
to fix it?
Thanks you
children of bodom is offline
post #2 of 5 (permalink) Old 03-10-2004, 11:24 PM
For the sake of the discussion, let's clarify. The quad is 2 preamps in one. Lets say amp 1 and amp 2. Each amp has 2 channels, lets say channel A and B. Is it one amp that's louder than the other? Or (I think) channel A louder than channel B? If so, is it that way on BOTH amps? Or just one of the amps? As a sidenote, I just want to make sure you're aware that channel A's gain is like the overall input gain of the "amp" (1 or 2) so that where you have it set influences the gain to channel 2.
frankfalbo is offline
post #3 of 5 (permalink) Old 03-11-2004, 07:52 AM Thread Starter
sorry I didnt clarify that, but the whole Channel B, so the second preamp is alot quieter.
post #4 of 5 (permalink) Old 03-11-2004, 11:38 AM
I would retube it.
Sounds like the 2nd channel tubes are failing ( any one of them can cause this, but if one is going, you may as well retube the whole channel if not the whole preamp)
Bamm
bammbamm is offline
post #5 of 5 (permalink) Old 03-11-2004, 12:51 PM
Sorry to be a stickler, but you contradicted yourself here, so I still don't know what you mean. I think you mean the bottom preamp. But Channel B to me refers to the "lead" channel on both amp A and amp B. It's probably my fault because I think the output jacks on the back of the amp refer to amp 1 as "A" and amp 2 as "B" so my attempt to have you clarify probably made it worse.
Lets assume you mean the bottom preamp, or Amp 2. That's like the MKIII sound. You said your "channel B output knob doesn't work. If by that you mean that you can't control the volume of Amp 2, what did you expect? That it would magically be the same level as amp 1? :P
I'm kidding, but if that's the case, it's obvious where the problem is. To replace the pot you would either buy a new pot (exact same rating and taper) from an electronics supplier or call Boogie and get them to send/sell you one. Then you can adjust both amps to balance properly with eachother.
I wouldn't call it tube related just yet, although they do use a completely different set of tubes for each amp. The quickest free way to check if that's your problem is to swap all the tubes from amp 1 with the tubes from amp 2 and see if the output difference reverses itself.
power amp
WTB Mesa Boogie Quad woksin Classified Ads: Guitars and Gear 0 02-16-2011 01:47 AM
FS: Mesa/Boogie Quad w/ FU2 footswitch Dr.StrangeNote Classified Ads: Guitars and Gear 2 10-30-2010 11:13 AM
FS: Mesa/Boogie Quad Preamp Dr.StrangeNote Classified Ads: Guitars and Gear 4 10-02-2010 01:34 AM
WTB: Mesa Boogie Quad Preamp sadbuttruely Classified Ads: Guitars and Gear 0 05-28-2008 02:22 AM
FS in Australia: Mesa boogie Quad preamp- $975 Ki swordsman Classified Ads: Guitars and Gear 0 07-04-2006 02:54 AM
