Microcab 1 white noise ? - Jemsite
post #1 of 6 (permalink) Old 10-22-2009, 08:07 PM Thread Starter
Angry Microcab 1 white noise ?
Hey dudes
So ive been using my microcab for a few weeks now , but i notice once its been on for 30 mins or so , sometimes longer, it starts to make this grym sound , like an electronic wind blowing , and it gradually gets louder and louder , until you cant record anymore , and have to leave the unit off for a while.
There is no set amount of time you have to leave it off, sometimes it works fine after 2 mins , other time you can plug it in 2 hours later and its still at the same point in its noiseyness - it is REALLY pissing me off, ruining good recording sessions and inspirational moments.
Its def the microcab as i have isolated it by removing 1 piece of my setup at a time.
Im about to open it and have a look - any ideas here dudes ?
Shredragrammaton is offline
post #2 of 6 (permalink) Old 10-22-2009, 08:11 PM Thread Starter
Re: Microcab 1 white noise ?
Just opened it, very surprised - not 1 spec of dust inside, absolutely mint like its brand new - WHERE IS THE NOISE COMING FROM !!!
post #3 of 6 (permalink) Old 10-22-2009, 08:50 PM
Whatever the problem is, it's thermal in nature. When you leave it on for X time, it gets hot and one of the parts is drifting out of spec. I had a similar problem with an MP-1. The hotter it got (over time), the less gain it had.
Sorry I can't be any more specific but I would go to the ADA Depot boards for more help.
toneboy is offline
post #4 of 6 (permalink) Old 10-22-2009, 09:20 PM Thread Starter
Ok so i mightve made an error , plugged everythign in seperately again
ITS MY ADA 3TM making the noise
-Even when i turn the 3tms main volume knob on the front right down , it STILL makes this horrible noise.
-I switched tubes there now , and it made no difference .
-I also run it through a ISP decimator which kills any noise, but not this one - ive even tried decimator AND tc gmajor noisegate and they dont effect the sound atall.
- I just switch OFF the ada mp1 3tm and its still making the noise !
never did this before
I have recorded it in mp3 form , firstly with the ada turned off , then i turn it on and gradually turn up the master vol knob whilst strumming , then fade it out again , you can hear the sound remain constant You might hear a -slight- hiss when the volumes right up but that is easily killed by the isp , its just this other sound thats causing the bother.
I can email any of yous the mp3.
post #5 of 6 (permalink) Old 10-22-2009, 09:21 PM Thread Starter
Posted this on ada boards too ,but thought id do it here too, for max help lol
post #6 of 6 (permalink) Old 10-22-2009, 10:00 PM
If the problem is with your 3TM MP-1 then it's probably the same problem mine had. It's a known issue with earlier revs of that mod and the fix is cheap and easy. I don't remember the specifics but one of the diodes needs to be replaced. The part itself is very inexpensive (less than $1).
toneboy is offline
FS: ADA MicroCab I GuitarEvan07 Classified Ads: Guitars and Gear 2 09-15-2009 11:09 AM
FS: (3) ADA Microcab 1s $75 each. toneboy Classified Ads: Guitars and Gear 3 06-25-2009 07:57 PM
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 08:00 AM
FS: ADA MicroCab II Near Mint finstah Classified Ads: Guitars and Gear 3 11-02-2007 02:02 PM
WTB ADA MicroCab I or MicroCab II toneboy Classified Ads: Guitars and Gear 2 06-28-2006 08:12 PM
