Midi Help - Jemsite
post #1 of 2 (permalink) Old 09-28-2005, 09:39 PM Thread Starter
Midi Help
ok i need some help.. i'm looking for a ground control (mostly considering behringer fcb1010) to run everyhting and i'm hearing all this stuff about a certain number of program change commands and control change commands. and people are upset that there aren't enough control changes etc. just what exactly is the difference between the two? does a single program change change a patch in only one unit? will i need two program changes in one preset on my footpedal to change my GCX switcher and my g major? I need a quick midi explanation here before i buy up a bunch of stuff and don't have a clue how to put it together. i've searched the net and haven't found anything that i really understand. can someone please help??? anything you can tell me that may be useful to a first time midi person. thanks a lot
adamcbest is offline
post #2 of 2 (permalink) Old 09-28-2005, 10:22 PM
Re: Midi Help
wow... I'm gonna need a drink before I sit down and answer this...
For starters, I think you've got the difference between program change and control change... program change is generally used to switch patches, and control change is generally used to adjust parameters within those patches. Sometime control change is an on/off toggle, other times it occurs over a continuous range (e.g., when you're using an expression pedal).
Add to that the concept of MIDI channels... each MIDI device can be programmed to respond only to messages sent on a specific MIDI channel, and generally MIDI foot controllers allow to to specify which channel(s) they send on.
Let's assume you assign your GCX to channel 1 and your G-Major to channel 2. You can now proceed to set up a bunch of programs on the ground control as follows:
1: channel 1 = program change #2, channel 2 = program change #4
2: channel 1 = program change #24, channel 2 = program change #56
So you can see, you can send separate program changes to each device. I believe the ground control allows you to program 8 different devices, sending different program change commands down each channel.
Hope this helps a bit.
--B
bduersch is offline
behringer fcb , expression pedal , midi foot , midi foot controller
MIDI Amp switcher for non-MIDI amps - Yes, Rivera too. :) jeffrey Gear, Equipment, Recording & Off Topic 1 03-28-2002 04:34 PM
voodu valve & midi mate! - preamps and midi controller peel Gear, Equipment, Recording & Off Topic 4 07-11-2001 10:34 PM
Midi programming - Help for the Midi challenged! oooo Gear, Equipment, Recording & Off Topic 0 05-27-2001 09:23 PM
GT-5 Midi control - how to use it as a midi controller? 7 Dying Trees Gear, Equipment, Recording & Off Topic 2 05-17-2001 09:01 AM
