More adobe audition help. - Jemsite
post #1 of 4 (permalink) Old 03-27-2011, 10:28 PM Thread Starter
Hey,
Sorry for so many recording question, im a noob at this stuff. I have a hp netbook with the recording software on it, and the headphone jack is the saqme for the mic jack, and i run a direct line to the computer, so i was wondering if i got a splitter, could i listen to the first track while i recorded track number two,
thanks, Jake,
eyebahnez is offline
post #2 of 4 (permalink) Old 04-01-2011, 03:19 PM
Re: More adobe audition help.
As in the audio output on your laptop is the same as the input? I've never heard of that before.
Bill Bixbie is offline
post #3 of 4 (permalink) Old 04-05-2011, 12:24 AM
Reviews: 8
This is more of an input/output question, than an adobe audition question.
I have never seen this before on a notebook either.
It sounds similar to the way the 3.5mm stereo jack works on the iPhone to me. The 3.5mm stereo jack also doubles as a mic input. That is why the mic on the handfree stereo headset works.
To answer your question with the splitter, I am not sure. I have heard of this done to get double mono etc with the output in other situations, while using a mic for input.
While on the topic of these wierd inputs, you guys have to check out IK Multimedia's iRig which take full advantage of the bidirectional jack on the iPhone: http://www.ikmultimedia.com/irig/features/
Such a cool idea! I have not heard in person the quality though. They also make a Stealth Plug which seems to be a USB version of a the same thing for PC. http://www.ikmultimedia.com/stealthplug/features/
Personally I would just find a USB audio interface to get your instrument into the PC. What audio interface will be your big question, as that is a huge choice, and there are many options. Then you select your audio interface as Input in Windows, and your normal sound card (onboard soundcard in your case) as output, in the sound recording software that you use, and just use that input/output jack as an output jack.
RichardFX is offline
post #4 of 4 (permalink) Old 04-18-2011, 05:04 PM
The headphone out and the Mic in are the same? That sounds a little strange. What you could do is buy a set of good USB speakers, that way you could monitor your first track while you use the Headphone/Mic jack in to record.
Stringz is offline
adobe , audition , netbook , spliter
Adobe Audition 3 eyebahnez Gear, Equipment, Recording & Off Topic 1 03-27-2011 07:50 PM
I will NEVER buy anything Adobe again! shredmaster Off-topic / Miscellaneous 26 11-24-2010 03:47 PM
College Audition Shredragrammaton Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 09-05-2010 07:29 PM
Can anyone help me with an adobe pdf file? Queens_Brian_May Off-topic / Miscellaneous 9 02-10-2008 01:27 AM
Adobe CS2 / Bridge issues! help! shredmaster Off-topic / Miscellaneous 0 04-29-2007 01:40 PM
