Well, want to do some home recording, so multi track recorder or PC with interface?
Pros and cons for both.
Yes, I have had this problem too. I have also had a fan that made my CRT screen shake if I set the refresh rate at anything other than 60Hz!Schutzfaktor12 said:No, you´re right, that´s a CRT problem. I had the same problem and it vanished when I got my TFT display.
Firewire has very high latency compared to PCI. Firewire alone, not taking into consideration any extra latency from the card is higher latency than any decent recording card.Ant1981 said:I understand from some things I have read, that the firewire interfaces make splendid interfaces with no latency issues also if you get the right interface. I understand that firewire runs pretty much of the same bus as PCI and can often actually offer more flexibility as there are many TRS and XLR inputs with variable gain.
Check out some of the M-Audios. Some of them have something like 10 XLR inputs and whatnot.Ant1981 said:I've never seen a pci card with 8 XLR ins, 8 trs ins, loads of gain controls, phantom power controls, meters, the lot that goes with it really.
Yes my NIC has one of those too... or if we're talking about the 60s-70s line of Mcintosh receivers, then I'm all for THOSE Macs.... I actually own onetoma said:mac's, all the way!!!!!
Go on, have a look, you know you want torgr said:Sounds good, I'm kinda out of the loop on the latest stuff, I'll look into those. Of course, I can't really afford any GAS right now, so maybe I won't look at what's out there:mrgreen:
