Need Help/Advice for using multiple Amps.. - Jemsite
post #1 of 4 (permalink) Old 08-04-2007, 03:52 PM Thread Starter
Hey guy.. I am curious, I have the amp i use for my metal band home at the moment.. I tried my fender supersonic combo into it, and it sounds WICKED (into the cabinet..) Then, due to my severe case of GAS, I started thinking of using both my amps into the cabinet, (left and right)... i started trying this out a second ago and was thinking about the possibility for live... I have heard of people using 2 amps, and blending a quieter clean tone with a dirty tone to maintain clarity.. I tried this but I didn't really have a chance to do it loud, nor did i have time to really tweak.. so my main questions would be
-what is ur experience with this kind of setup
-i am using a boss chorus ensemble to split the signal, do i lose a lot of tone doing so ( this is just to test it...)
-would i run one amp clean, one dirty, and use the footswitch for the dirty amp??
-can I rig it up so i can switch both amps with only one footswitch (midi??)
-is this a bad idea with only one cabinet ( my goal is not to A/B to different amps, I want to mix the 2 to get a thicker and unique sound..)
-can u tell the difference between delivery and d'journo??
I appreciate all comments, please help me out!! I don't want the gas tank to go empty, or I'll get addicted to porn or World of Warcraft---Please help a fellow GAS'er
shogun is offline
post #2 of 4 (permalink) Old 08-04-2007, 05:24 PM Thread Starter
Re: Need Help/Advice for using multiple Amps..
help.......
shogun is offline
post #3 of 4 (permalink) Old 08-04-2007, 08:17 PM
Reviews: 12
i'm working on a similar setup for my rack... it's 2 preamps into a single poweramp. the "connection logic" for your proposed setup sounds feasible but expenses will range depending what goes in the chain and where the signal is going before it is amplified but it looks like you'll need a switching system and/or mixer.
i'll let ya know in 6 months :P
if the fx does not have "true bypass", tone can be affected. I'd place the chorus somewhere in the FX loop. To split the signal to feed 2 amps at the same time, you can try:
a) buffered splitter
b) ABY switch
c) a long Y cable
that's only the beginning...
clean amp can be disabled / enabled in conjunction with dirty amp disabled / enabled... depending on the midi switching system used.
sure... depending on the amount of relays available on the midi switching system, it can range from 2 mono relays to 4 stereo relays or a combination (unless you get it custom).
not a bad idea... I think the mixer will be in the FX loop and have the mixer's L output to amp1 return + mixer's R output to amp2 return. dunno if it'll work but it might be simpler if each amp had it's own cabinet however just to avoid a costly and more complex setup....
sure... one doesn't come with philly cheesesteak
GAS can be a pita if ya don't know how to diagram your signal path first. You'll end up buying gear that doesn't maximize your setup's capabilities. I'd start off simple first (guitar -> amp1 + amp2) then expand and explore from there. I'd also start researching the manuals for the equipment that'll be placed in the chain.
Enjoy your experiments and share your experience. Feel free to PM me if you need help in gear recommendations.
Reg
reguv760 is offline
post #4 of 4 (permalink) Old 08-05-2007, 01:16 PM Thread Starter
your advice is well appreciated!
shogun is offline
boss chorus , clean tone
The Jemsite guide to amps Mr Orange Gear, Equipment, Recording & Off Topic 123 04-06-2016 01:27 PM
Car Audio Amps vs. Guitar Amps Jeff Gear, Equipment, Recording & Off Topic 8 09-01-2003 07:47 AM
Amps amps amps Grev Gear, Equipment, Recording & Off Topic 10 02-22-2003 01:18 AM
Review of my Voodoo Amps Modded TSL-100 Gresh Gear, Equipment, Recording & Off Topic 7 01-05-2003 09:08 PM
Amps, amps and more amps... - Suggestions...there are too ma carlos seo Gear, Equipment, Recording & Off Topic 4 05-17-2001 01:53 PM
