Need info on Boss DS-1 please - Jemsite
post #1 of 5 (permalink) Old 03-12-2004, 11:44 PM Thread Starter
I own a Boss DS-1 that has a black label on the bottom that says Products of Roland Made in Japan.It has a silver screw to access the battery and a black switch I guess you could call it that moves up and down with the pedal.There is a number 9300 in black in the battery compartment.Is this some kind of rare model?I have no idea.Thanks for any help.
mitchmarshall is offline
post #2 of 5 (permalink) Old 03-12-2004, 11:48 PM Thread Starter
Boss Ds-1 More info
By the way it also has a small screw on the side of each of the 3 knobs if that helps.Thanks
post #3 of 5 (permalink) Old 03-13-2004, 02:53 PM
Black label/MIJ are usually worth a bit more than MIT, and the silver screw bumps up the value even more. I believe this means it was a very early model, particularly of interest to a collector, or player who believes it sounds better than recent issues.
Greg
gkelm is offline
post #4 of 5 (permalink) Old 03-13-2004, 03:03 PM Thread Starter
Thanks that helps alot. 8)
post #5 of 5 (permalink) Old 03-13-2004, 04:19 PM Thread Starter
Please lock this post.Thanks MM
Closed Thread
PatchMate, Whammy II, Xotic RC, Boss TR-2, POG, TC Phaser, Digi RV-7, BOSS DS-1 Sevenstringer Classified Ads: Guitars and Gear 8 05-30-2012 08:32 PM
FS: BOSS MT-2 (Metal Zone), BOSS TR-2 (Tremolo), and DiMarzio PAF Pro redaxe Classified Ads: Guitars and Gear 0 04-17-2012 09:55 PM
FS Boss Pedals, Boss Pedal Board, and SD Pickup Booster CosmicDebris Classified Ads: Guitars and Gear 3 09-17-2008 07:18 PM
Original TC XII Electronic Phaser& Power Supply, BOSS TU-2, BOSS OC-2 Sevenstringer Classified Ads: Guitars and Gear 1 10-23-2007 06:57 PM
WTS: Boss Super Chorus CH1 & Boss Compression Sustainer CS-3 Clydefrog Classified Ads: Guitars and Gear 1 07-15-2006 12:57 PM
