Noise Supressor in Effects Loop - Jemsite
post #1 of 3 (permalink) Old 07-03-2007, 06:44 PM Thread Starter
I have a Boss NS-2 and I am thinking that (when I get back as it is away getting repaired ) I might try putting it in it's effects loop (that I currently do not use).
If I were to just put the pedal itself into an effects loop, how would I wire it up? Now this typically would be a very simple thing, however the NS-2 only suppresses the noise of pedals in its send / return loop.
So how would I wire the Send / Return loop of the amp to the Send / Return loop of the NS-2? I was thinking:
Amp Send > NS-2 Input > NS-2 Send > Patch Cable to NS-2 Return >NS-2 Output > Amp Return.
Yay? Nay?
Cheers.
Gudster is offline
post #2 of 3 (permalink) Old 07-03-2007, 06:55 PM
Re: Noise Supressor in Effects Loop
the amp send, into the ns-2 return, then the ns-2 send to the amp return
yoyo1299 is offline
post #3 of 3 (permalink) Old 07-08-2007, 11:22 PM
The only thing I put in the loop is my delay.
Everything that creates noise, like the distortion, overdrive, compression, etc is all ran into the front end, therefore that's where the NS-2 goes.
surfdog777 is offline
Effects loop volume drop in Prosonic sanchez Gear, Equipment, Recording & Off Topic 3 05-31-2005 08:06 PM
Effects loop squeeling Beavis Gear, Equipment, Recording & Off Topic 3 04-01-2003 01:28 PM
fender twin reverb and effects loop? SilverSurfer2 Gear, Equipment, Recording & Off Topic 0 02-07-2003 12:49 AM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear, Equipment, Recording & Off Topic 5 02-13-2002 09:55 PM
Dilemma with effects loop. Josh Blagg Gear, Equipment, Recording & Off Topic 3 05-19-2001 07:11 PM
