which ohm setting to use? - Jemsite
post #1 of 7 (permalink) Old 10-18-2010, 01:12 PM Thread Starter
I've got a simple (and most likely stupid) question.
My head is has a plug on the back for 4 ohm speakers and 1 for 8 ohm speakers.
my cab is a 2x12 with 4 ohm speakers.
Im thinking I gotta run from the 4 ohm plug on the head, but I just want to be sure.
RI_RGplayer is offline
post #2 of 7 (permalink) Old 10-18-2010, 04:14 PM
Reviews: 120
Re: which ohm setting to use?
Yes, it is pretty obvious isn't it?
You have a 4ohm cab, plug it in the 4ohm plug. If in doubt consult your amps manual.
LonePhantom is offline
post #3 of 7 (permalink) Old 10-18-2010, 05:33 PM
Reviews: 10
It's not a stupid question at all...
If the cab is clearly labeled as a 4 ohm cabinet then easy enough - connect it to the 4 ohm plug on your amp...but if the cabinet isn't labeled and you can see that the speakers are labeled as 4 ohm speakers then they are likely wired in series, which would create 8 ohms of resistance and you could use the 8 ohm plug.
Here is my understanding of speaker wiring and matching impedance: two 4 ohm speakers wired in series (likely in this scenario) would create 8 ohms of resistance but two 4 ohm speakers wired in parallel (less likely in this scenario) would create less than 4 ohms of resistance. A saying that helps to remember is "low into high will fly but high into low won't go" meaning that you could run a 4 ohm head into an 8 ohm cab without any problems but running a 8 ohm head into a 4 ohm cab would be inviting problems. So in your case if your aren't sure of the wiring and resistance of your speaker cab then the 4 ohm setting will likely be the safer option but if you can confirm that the two 4 ohm speakers are wired in series then I would use the 8 ohm plug.
The safest thing to do is to check with a voltage meter (most voltage meters have an ohm setting to measure resistance). The voltage meter likely won't read exactly 4 or 8 ohms so check the reading and go with the closest lower ohm setting on your amp.
This is all based on my understanding of speaker wiring & impedance but perhaps someone else can chime in and confirm the info in my post to give you some added piece of mind...
doriangrey is offline
post #4 of 7 (permalink) Old 10-18-2010, 05:41 PM Thread Starter
yeah, its two 4 ohm speakers in wired in series, thats where my apprehension came from
post #5 of 7 (permalink) Old 10-18-2010, 05:53 PM
Reviews: 10
If you know that the speakers are wired in series then my understanding is that they should create 8 ohms of resistance and I would go with the 8 ohm setting...
BUT if you are unsure and/or uncomfortable going with the 8 ohm plug then go with the 4 ohm plug because you are safer running low into high than you are running high into low...
I made an error with impedance matching once and it fried the tubes in my amp (they actually lit up like christmas lights before frying) and I'm lucky I didn't do more damage than that and catch my amp on fire...
maybe someone else can confirm to give you some added piece of mind...I know I always like to get a couple of opinioins before I do something I'm unsure of ;o)
post #6 of 7 (permalink) Old 10-18-2010, 07:33 PM
Reviews: 120
Sorry I mis-read your post, I thought you were saying the cab said 4 ohms. Something should be listed on the back of cab telling you what it should be plugged in to though.
post #7 of 7 (permalink) Old 10-22-2010, 01:50 AM
doriangray is correct. Just to help clarify whether your speakers are setup series or parallel, look at how they are wired. For series, they would be wired from each speaker's positive to the other's negative. If they are wired from positive to positive and negative to negative, they are parallel. Just a reminder that if the speakers are mounted with the terminals facing each other (set to the middle of the cabinet) the wires would cross if they were wired in parallel, go straight across from terminal to terminal if in series.
Check out Celestion's website, click on Ask Dr. Decibel, select Speaker Wiring Diagrams under Dr. Decibels secrets and it will show you the different options for wiring.
sonofiam is offline
ohms , settings
Setting up a Jem & Lo Pro jonboyuk Tech: Setup, Repairs and Mods 6 01-21-2009 10:18 PM
setting ur guitar up JasonMalmsteen Tech: Setup, Repairs and Mods 30 01-31-2007 01:03 PM
Setting Up - Seriously need some help here Scoff X Tech: Setup, Repairs and Mods 1 03-15-2002 10:41 PM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux Ibanez JEM, UV, JS & Other Signature Models 2 06-28-2001 02:56 PM
Jem 7VW *Setting up trem to go up - Jem set up toneseeker Ibanez JEM, UV, JS & Other Signature Models 1 12-22-2000 12:23 PM
