ohms - Jemsite
post #1 of 7 (permalink) Old 12-21-2005, 12:33 AM Thread Starter
ohms
I get my JSX head for Xmas and I was wondering what do the ohms switches do?
The head can either be 4,8, or 16 ohms mono, or 8 stereo or something.
It says when it does this the tubes go to 6l6's or something.
Does this mean if i lower the ohms the amp runs at a lower wattage ?
wallie! is offline
post #2 of 7 (permalink) Old 12-21-2005, 06:42 AM
Re: ohms
The Ohms switch is for matching different speaker cabinet combinations to ensure the power output is matched with the speakers, as speakers are in a way a load with reistance to the amps power. For example, a 2 x 12" cabinet will be 8ohms, 4 x 12" is 16ohms, two 4 x 12's will produce an 8 ohm load, two 2 x 12's is 4ohms. Thats a simple way to explain this without going into ohms law and getting too technical!
I hope this helps. Let me know how you get on with the Amp.
Ant1981 is offline
post #3 of 7 (permalink) Old 12-21-2005, 07:16 AM Thread Starter
Re: ohms
ah k
Also i read the amp specs again and it means the EL34's can be replaced with the 6L6EC's or whatever their names are :P
Cool
Amp arrives friday, i get it on xmas, cant wait
My teacher who organised it is a top bloke
wallie! is offline
post #4 of 7 (permalink) Old 12-21-2005, 11:25 AM
Re: ohms
Cool, I'm thinking of getting a Marshall TSL100 so that I can channel switch clean and overdrive keeping that vavle tone, the tone is lost with a distortion/overdrive pedal. But I'm interested to know what the JSX sounds like.
Ant1981 is offline
post #5 of 7 (permalink) Old 12-21-2005, 03:38 PM
rgr
Re: ohms
1st, the ohms switch has nothing to do with the type of tubes, there is another switch for 6L6 or EL34 tubes, this needs to be set to the type you are using.
Totally correct.
Only if the 2-12 has 16 ohm speakers wired in parallel and the 4-12 has 16 ohm speakers wired in series/parallel. Too many assumtions here, there are 4, 8, and 16 ohm 2-12s as well as 4-12s, it depends on the speakers and how they are wired. Better to just leave it at you set the ohms to match a single cabinet. If you are using 2 cabinets, 2X 8 ohm cabinets in parallel (which is the standard way they are hooked up) is a 4 ohm load, 2X 16 ohm cabs are an 8 ohm load. Can't use 2X 4 ohm cabinets unless you run them in series, if you don't know what that means, please don't hook up 2 4 ohm cabs.
Based on your questions, you'll want to read your manual carefully on a tube amp, they aren't as forgiving as SS amps about being hooked up incorrectly.
Roger
rgr is offline
post #6 of 7 (permalink) Old 12-21-2005, 03:54 PM
Re: ohms
also never have your amps standby turned on unless you have a speaker or speaker's hooked to it
honky_tonk is offline
post #7 of 7 (permalink) Old 12-22-2005, 04:15 AM Thread Starter
Re: ohms
Ive played on it a few weeks ago (the actual one joe used on tour)and it sounds great
The clean channel is very clean :P So if the need arises to use pedals, they will go well :P
The crunch channel seamed pretty good, the gain around 5 got me a really nice sound.
The ultra channel (my favorite) sounded great on gain 5 as well, pushing that gets that really great sustained distorsion
The noise gate is orsm, especially on the ultra channel, especially with single coils, eliminating the hum , although ive read there is a slight loss in tone
The presence and resonace controls are great as well, if ur favourite settings dont sound right (say in a hall,a few adjustments of these controls and u will be right). Aside from the fact it doesnt have reverb, it was a great amp to play on, and it did blow me away. Ill post more up after xmas:P
wallie! is offline
jsx head , marshall tsl , ohm cab , ohm cabinet , ohm load , ohm speaker , ohm speakers , overdrive pedal , speaker cab , tube amp
ohms help astro929 Gear, Equipment, Recording & Off Topic 2 06-09-2009 02:32 PM
WTB: THD hotplate - 8 Ohms Jaden Classified Ads: Guitars and Gear 7 01-25-2009 12:41 PM
Question about ohms. Ibanezgrx405 Gear, Equipment, Recording & Off Topic 1 10-21-2008 09:41 AM
How many Ohms ? megadeth Gear, Equipment, Recording & Off Topic 4 07-05-2005 10:16 AM
Ohms ? - 8 ohms 16 ohms who gives a .... jem7pbk Gear, Equipment, Recording & Off Topic 10 05-23-2001 03:14 AM
