Peavey VK 1x12 farting...help - Jemsite
post #1 of 2 (permalink) Old 10-28-2010, 11:53 AM Thread Starter
VCR
Hi
I have a Peavey Valveking 1x12 and I have a problem. Every now and again I get a "farting" type noise out of the amp. Sometimes just a small one and other times it will go on for up to 10 seconds or so. I put name brand tubes in it a year ago (only mod).
Can't really think of a better way to describe noise. While noise is going guitar rings through, it does not over take signal. Almost sounds like a guitar with a bad input or maybe a bad patch chord. Close to this type of sound but not as "Bright" of a noise if you will.
I have multiple guitars and patch chords with other amps. Saying this just to state I have gone threw the ideas of the guitar or chord being at fault. Also the guitar does not have to be plugged in for the noise to happen too. I'm in no hurry to take this to a repair guy, repair cost might outway value of amp.
Any advise?
VCR is offline
post #2 of 2 (permalink) Old 10-28-2010, 12:27 PM
CosmicDebris's Avatar
Re: Peavey VK 1x12 farting...help
I had same issue with my 212 and unplugging the reverb tank took care of that. I use a multi effects so I don't need the amps reverb.
Peavey Valveking amps are POS's. I go out of my Boss GT6 intothe effects return to get a good sound out of the amp. The only reason I don't get rid of it is because I am not going to saddle someone else with this POS.
If I use the amp gain on itself it is noisey, squeels, and hisses. I have tried replacing the tubes with tube from EuroTubes but not much of a change.
VK's are just crap amps. Btw, the one I currently have is the third one as the first two were returned and they won't take back this one claiming there is "nothing" wrong it it despite the "farting" sound and other issues.
CosmicDebris is offline
Similar Searches
Why is my amp "farting out
WTT - Peavey VTM60 tube head and JBL 2X12 Cab for 1X12 combo jemjem Classified Ads: Guitars and Gear 1 03-20-2009 12:33 PM
Peavey Triple XXX 1x12 Combo $450 cjl5150 Classified Ads: Guitars and Gear 3 01-08-2008 04:04 PM
FS: Crazy good deal on a Peavey USA Transtube Studio Pro 1x12 amp Queens_Brian_May Classified Ads: Guitars and Gear 1 11-06-2007 04:26 PM
FS:Peavey XXX 1x12 60w All Tube w/Eurotubes - $500 scarello Classified Ads: Guitars and Gear 0 03-21-2005 12:41 PM
F/T: Peavey Ultra 60 Watt 1x12 amp For...... Jackson Soloist Classified Ads: Guitars and Gear 0 02-13-2005 09:51 PM
