Pedal power supply question - Jemsite
post #1 of 6 (permalink) Old 03-30-2016, 10:38 PM Thread Starter
I just picked up a BOSS CE-5 and used a 9v power supply and the power supply blew out. I could hear something pop. Before this the pedal wasn't working with it anyway, I go no sound. So I went and got a 9v battery to make sure the pedal is OK, and it works perfect. Now I need a new PS, I looked at the tech specs and the pedal requires 9v/200mA (the one I had was 9v/500mA, but it was old). The recommended one is PSA-120 but it's discontinued and replacement is 120S or T, but they have different specks...Long story short does anyone use these for the ce-5? I don't want to spend the extra money if not needed but I don't want to keep having my ps go bad on me. Thanks!
hilljack13 is offline
post #2 of 6 (permalink) Old 03-31-2016, 04:04 AM
Re: Pedal power supply question
Any voltage stabilized power supply with 9V and minimum 200mA will do. Original 120S or T is fine also, which one does not matter. With the Boss you don't have to worry about the plug size and the polarity.
A quality brand device is more expensive, but will most likely be more hum-free and live longer.
Like you wrote, your PS with 500mA cannot have been overloaded and probably just failed because it was old.
Jemerator is offline
post #3 of 6 (permalink) Old 03-31-2016, 09:58 AM Thread Starter
Thanks, I think I just needed some reassurance. The PS was like 10+ years old.
Off topic - You from Germany? I just spent 3 years in Stuttgart.
post #4 of 6 (permalink) Old 03-31-2016, 11:25 AM
Great, so you know Germany very well. What did you do here?
Long ago i had a friend from Tempa Bay.
post #5 of 6 (permalink) Old 03-31-2016, 07:21 PM Thread Starter
I was stationed there for the military. I'm sad now 'cause I'm about to miss Frühlingsfest.
post #6 of 6 (permalink) Old 04-06-2016, 12:56 PM
What worked for me, and may not be the answer is the joyo JP-01 power supply. It is inexpensive, has a small foot print for a "power brick" and has 8 9v ports and 2 18v ports for more power hungry pedals. I use mine all the time.
Phantomotaku is offline
ce-5 , psa-120
FS/FT: MXR 10 Band EQ Pedal M-108 w/ Power Supply Chewy5150 Classified Ads: Guitars and Gear 0 10-09-2013 10:12 AM
Noisy Pedal Power Supply skins345669 Tech: Setup, Repairs and Mods 11 04-18-2011 04:07 PM
WTB: Pedal Power Supply Gilberto99 Classified Ads: Guitars and Gear 0 02-07-2010 11:06 PM
FS: Ibanez Lo-Pro, pedal power supply ZOMB13 Classified Ads: Guitars and Gear 0 06-26-2009 02:58 PM
WTB : Morley Power Supply for my BH 2 Wha pedal sweetnsour30 Classified Ads: Guitars and Gear 1 11-27-2008 10:33 AM
