Peterson VS-1 V1.9 - much better sync with string vibration - Jemsite
post #1 of 4 (permalink) Old 02-24-2003, 05:50 PM Thread Starter
I've sold my old VS-1 to a friend of mine who lives in Russia, and bought myself a new one. They've fixed the only bad thing I could find in the old version - sync instabilities. In the previous version strobe pattern would sometimes suddenly go out of sync with the string and start moving erratically. This problem was pretty frequent with a high E string during the decay stage of its vibration. It looked like the input level was adjusting by the peak when you hit the string and remained the same until it decays completely. It is now much better. And when it decays below the range the tuner can sense it shows either bb or ## instead of erratically moving strobe pattern. I don't know what they've done to it to improve on this, but the user experience is just sooo much better now!
microdmitry is offline
post #2 of 4 (permalink) Old 02-24-2003, 09:22 PM
How do you find out which version of the firmware is on a VS-1? Is it on the case somewhere, or can you access it via the onboard software?
darren wilson is offline
post #3 of 4 (permalink) Old 02-24-2003, 09:34 PM
I've noticed that problem with mine. I can live with it though.
CrossingStar is offline
post #4 of 4 (permalink) Old 02-25-2003, 11:06 AM Thread Starter
Easy. When you turn it on it shows V1.9 on its screen.
darren wilson
Edge Zero II Saddle Vibration CudBucket Tech: Setup, Repairs and Mods 10 04-06-2014 09:22 AM
Multi effect with MIDI Clock sync ? zEr0 Gear, Equipment, Recording & Off Topic 0 10-14-2008 10:37 AM
String Vibration Problem CosmicDebris Tech: Setup, Repairs and Mods 3 01-01-2008 09:36 PM
Audio out of sync in Cubase VST Azrael Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 12-04-2004 03:04 PM
vibration...cab problem? somata Gear, Equipment, Recording & Off Topic 2 12-16-2002 11:31 AM
