piranha/g major channel changing question - Jemsite
post #1 of 3 (permalink) Old 05-22-2003, 09:32 PM Thread Starter
i'm new to rack gear and just need to be sure on this
if i was to get a rocktron piranha and TC Gmajor
can i hook them up so that when i change patches on midi pedal controller
(midimate or ground control maybe)
it automatically changes effect on Gmajor and channel on the piranha?
ie: effect and channel are both programmed into patch
any help would be much appreciated
Ki swordsman is offline
post #2 of 3 (permalink) Old 05-22-2003, 11:44 PM
Yes, if they're both midi operated (which they are indeed). Almost unlimited possibilities.
Greg
gkelm is offline
post #3 of 3 (permalink) Old 05-23-2003, 12:18 AM
It will also work if the Rocktron can be swtiched with 1/4" footswitches. You can switch one or two items using the jack on the back of the G-Major. (works great... I use it to swtich the FX loop and Reverb on my Mesa Mark IV)
--B
bduersch is offline
mesa mark , midi pedal , rocktron piranha
TC G Major Question Shredragrammaton Gear, Equipment, Recording & Off Topic 4 01-10-2009 05:49 PM
Question for G-Major users badguitarist All Other Guitars (including Prestige) 3 04-14-2008 07:11 AM
Single channel ram versus Dual channel ram results. Rotti Off-topic / Miscellaneous 3 01-03-2008 01:18 PM
String changing question Onizuka Tech: Setup, Repairs and Mods 18 03-23-2005 01:48 PM
Rivera TBR-1SL/G-Major Pre-amp channel-switching question vaijem777 Gear, Equipment, Recording & Off Topic 1 09-03-2002 09:54 AM
